How can I check each row for 2 values [counties & township]? Loop and if they match the dictionaries below, continue the If True statement than do something. My script right now is super slow. Processed 2 counties in 3 hours.
<SPAN class="comment token">#Import system modules</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env
<SPAN class="keyword token">import</SPAN> os
<SPAN class="keyword token">import</SPAN> time
counties <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"RIC"</SPAN><SPAN class="punctuation token">,</SPAN>\
<SPAN class="string token">"ASD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ATB"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"TUS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HOL"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"STA"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SUM"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CAR"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"TRU"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WAS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"FAI"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"COL"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WAY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"GEA"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"LAK"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HOC"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MRW"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MAR"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MAH"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"FRA"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"GUE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HAS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"POR"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CRA"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CUY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"COS"</SPAN><SPAN class="punctuation token">]</SPAN>
townships <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"SANDUSKY"</SPAN><SPAN class="punctuation token">,</SPAN>\
<SPAN class="string token">"MILTON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WELLER"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MORGAN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ORWELL"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"LENOX"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MONTGOMERY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MADISON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MIFFLIN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WAYNE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WALNUT CREEK"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ROME"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"PERRY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"PIKE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SPRINGFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"TWINSBURG"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MONROE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SUGAR CREEK"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"TUSCARAWAS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"AUGUSTA"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BROWN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ORANGE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ROSE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MESOPOTAMIA"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WARREN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"FAIRFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MILL"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SANDY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"FEARING"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"VIOLET"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SALEM"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BUTLER"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"KNOX"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ADAMS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MUSKINGUM"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SALT CREEK"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WATERFORD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WATERTOWN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MONTVILLE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"GREEN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"PAINT"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WOOSTER"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BAUGHMAN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CHESTER"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CHIPPEWA"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"PAINESVILLE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CONCORD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"FALLS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"NORTH BLOOMFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BIG ISLAND"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"GRAND PRAIRIE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CANFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ELLSWORTH"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"AUSTINTOWN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"FRANKLIN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WESTLAND"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"TULLY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SCOTT"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"NORTH"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"RIPLEY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MARION"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"PLEASANT"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"VALLEY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"GREENFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"AUBURN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"LIBERTY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CHARDON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"EAST UNION"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BERLIN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"NEWBURY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"PARKMAN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BLOOM"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HARDY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"DEERFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"TROY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ATWATER"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MECHANIC"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SUFFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WINDHAM"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"JACKSON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HAMBDEN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WASHINGTON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"WHETSTONE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"URBAN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MANTUA"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HUNTSBURG"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MUNSON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SOUTHINGTON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"RANDOLPH"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"PRAIRIE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CLARK"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CRAWFORD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"THOMPSON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"POLK"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"NEWTON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BETHLEHEM"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"LAWRENCE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HOWLAND"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"FARMINGTON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BRACEVILLE"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BAZETTA"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BRISTOL"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CANAAN"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"CHAMPION"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BLOOMFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BROOKFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MIDDLEFIELD"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"BURTON"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"LEROY"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HAMILTON"</SPAN><SPAN class="punctuation token">]</SPAN>
mxd <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CURRENT"</SPAN><SPAN class="punctuation token">)</SPAN>
df <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Layers"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
lyr <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListLayers<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ohioGrids"</SPAN><SPAN class="punctuation token">,</SPAN> df<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> lyr <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListLayers<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">==</SPAN> <SPAN class="string token">"ohioGrids"</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> a <SPAN class="keyword token">in</SPAN> counties<SPAN class="punctuation token">:</SPAN>
b <SPAN class="operator token">=</SPAN> <SPAN class="string token">"%s"</SPAN> <SPAN class="operator token">%</SPAN> <SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># </SPAN>
<SPAN class="comment token">#print ("%s" % (b))</SPAN>
<SPAN class="keyword token">for</SPAN> c <SPAN class="keyword token">in</SPAN> townships<SPAN class="punctuation token">:</SPAN>
d <SPAN class="operator token">=</SPAN> <SPAN class="string token">"%s"</SPAN> <SPAN class="operator token">%</SPAN> <SPAN class="punctuation token">(</SPAN>c<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># </SPAN>
<SPAN class="comment token">#print ("%s" % (d))</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ohioGrids"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"CLEAR_SELECTION"</SPAN><SPAN class="punctuation token">)</SPAN>
cnty <SPAN class="operator token">=</SPAN> <SPAN class="string token">'"COUNTY_CD" = \'%s\''</SPAN> <SPAN class="operator token">%</SPAN> b
seperator <SPAN class="operator token">=</SPAN> <SPAN class="string token">" AND "</SPAN>
twpship <SPAN class="operator token">=</SPAN> <SPAN class="string token">'"TOWNSHIP_N" = \'%s\''</SPAN> <SPAN class="operator token">%</SPAN> c
lyr<SPAN class="punctuation token">.</SPAN>definitionQuery <SPAN class="operator token">=</SPAN> cnty <SPAN class="operator token">+</SPAN> seperator <SPAN class="operator token">+</SPAN> twpship
result1 <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ohioGrids"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#print('{} has {} records'.format("ohioGrids", result[0]))</SPAN>
<SPAN class="keyword token">if</SPAN> result1 <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">#arcpy.RefreshActiveView()</SPAN>
<SPAN class="comment token"># GetExtent</SPAN>
lyr <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListLayers<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ohioGrids'</SPAN><SPAN class="punctuation token">,</SPAN> df<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
ext <SPAN class="operator token">=</SPAN> lyr<SPAN class="punctuation token">.</SPAN>getExtent<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
df<SPAN class="punctuation token">.</SPAN>extent <SPAN class="operator token">=</SPAN> ext
<SPAN class="comment token"># SelectLayerByLocation</SPAN>
selection <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByLocation_management <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Meters"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"WITHIN"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ohioGrids"</SPAN><SPAN class="punctuation token">)</SPAN>
result <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN>selection<SPAN class="punctuation token">)</SPAN>
count <SPAN class="operator token">=</SPAN> int<SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">.</SPAN>getOutput<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> count <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"COUNTY: "</SPAN> <SPAN class="operator token">+</SPAN> b <SPAN class="operator token">+</SPAN> <SPAN class="string token">" & "</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"TOWNSHIP: "</SPAN> <SPAN class="operator token">+</SPAN> d
<SPAN class="keyword token">print</SPAN> count
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
