Hi all,this is my code:..zoom = arcpy.mapping.ListLayers(mxd,cut,"")[0] # we locate cut layer in TOC. cut is a variable
df.extent = zoom.getExtent() # Zoom to Layer zoom
df.scale = 20000 # we set the scale to 1:20,000
arcpy.RefreshActiveView()
arcpy.RefreshTOC()
mxd.save()
it should work, right?Well, when I open the map in PDF that I have generated and..time after time, I see Scale = 1:8,223, which means that after the Zoom to Layer, the line:df.scale = 20000 does not work at all!! (df is the DATA FRAME previously created)Any suggestions?Thanks in advance.Jose.
