I'm working on an application that requires that the infoWindow pop ups work outside of the map as well as inside. I have the pop up working, but for some reason there is no background, just text. I've created an infoWindow object like this:<div data-dojo-id="infowindow"
data-dojo-type="esri.dijit.InfoWindow" ></div>
Once I get the data I need from my database, I do this:infowindow.setTitle("Milepost Summary");
infowindow.setContent(milepostEntityResults.innerHTML);
I then do an infowindow.show to make it pop up. This all works, but when I get my pop up, it's just text, no background. If I change my code back to the way it was before I had the requirement of pop-ups outside of the map, everything looks fine. This is by creating the infoTemplate, adding it to the graphic and triggering it that way. However, I can't take this infoWindow outside of the map. Does anyone know what might cause this?
