I have tried both SDE and shapefile dynamic layers. Every layer that I try is failing in the same way.
If I do the following:
var featureTable = new ServiceFeatureTable() {
ServiceUri = dynamicLayer.ServiceUri + "/dynamicLayer",
Source = dynamicLayer.DynamicLayerInfos[0].Source};
await featureTable.InitializeAsync();
I get an exception -> {"\"key not found\" : "}
at RuntimeCoreNet.Interop.HandleException(Boolean retVal)
at RuntimeCoreNet.CoreFeatureSource..ctor(String path, String featureServiceJson, CoreSpatialReference sr_override)
at Esri.ArcGISRuntime.Data.ServiceFeatureTable.CreateFeatureSource(SpatialReference sr_override)
at Esri.ArcGISRuntime.Data.ServiceFeatureTable.<>c__DisplayClass5f.<InitializeAsyncInternal>b__5d()
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
If I take a step back and try to query the service as follows:
QueryTask queryTask = new QueryTask(new Uri(dynamicLayer.ServiceUri + "/dynamicLayer"));
var query = new Query("1=1");
query.ReturnGeometry = true;
query.OutFields.Add("*");
query.Source = dynamicLayer.DynamicLayerInfos[0].Source;
var queryResult = await queryTask.ExecuteAsync(query);
var featureSet = queryResult.FeatureSet;
My FeatureSet has 1 field (the Oid field). The graphics returned have 1 attribute (the Oid field). But I know these layers have other fields that are not being returned. In fact I can load an equivalent service and query in the same fashion in the WPF implementation that I came from and all of the fields are returned. I need to be able to label my SDE layers with more than just the Oid column. I'm certain it's not my data because I can reproduce with any of the shapefiles from the samples. Please tell me this isn't broken!!!
