I'm new to ArcGIS Server.
I have a ArcGIS Desktop map that I've connected to an Oracle database via Database Connections in the Catalog. The data is contains my customers with Longitude and Latitude fields. I want to publish that map to our internal ArcGIS Portal Dev and then Prod environment. The database in the Dev environment is different than the Production environment.
1. How do I set up database connections in the Server/Portal environment?
2. Can I parameterize the database connection so that the database connection does not have to be edited when publishing to each of the environments?
RQ
