I have some code I've written to allow users to print a map. When the map is printed it is printed at a scale that is not the same as the current map Scale. Here is the code:
function doprintclck() {
var incleg;
var tst = $('#legchkbox').prop('checked');
//Set incleg variable based on checked property of legchkbox. This is used to add or hide legend
if ($('#legchkbox').prop('checked')) {
incleg = true;
}else {
incleg = false;
var sctxt = $('#inptscale').val();
//Test to see if it is a number
//TODO Put this into an input function for the input box
//if (isNaN(Number(sctxt))) {
//var sc = Math.round(map.getScale() / 12);
//$('#inptscale').val(sc);
//return;
//Get Scale from input box as RF
var outscale = $('#inptscale').val() * 12;
//Create Print Map
createprintmap(incleg, outscale);
function createprintmap(leg, scl) {
console.log(leg, scl);
require(["esri/tasks/PrintTemplate",
"esri/tasks/PrintParameters",
"esri/tasks/PrintTask",
"esri/SpatialReference",
"esri/tasks/LegendLayer"
], function(PrintTemplate, PrintParameters, PrintTask, SpatialReference, LegendLayer) {
var urlToThePrintServer = "
https://qbygis.queensbury.net/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task";
//Create map title
var mTitle;
if (ptitle !== "") {
mTitle = "Parcel ID: " + ptitle + " Vicinity Map";
console.log(mTitle);
}else {
mTitle = "Queensbury Vicinity Map";
//Get visible layers to add to legend
var legitems = getLegLyrs();
//Create Print Template
var pt = new PrintTemplate();
//Create Map Legend
var ll = new LegendLayer();
ll.layerId = "layer2";
//if include legend not checked show no legend
if(leg != true) {
ll.subLayerIds = [{}];
}else{
ll.subLayerIds = legitems;
//Set Print Template Options
pt.layoutOptions = {
titleText: mTitle, //"Title",
copyrightText: "Map Produced by Queensbury GIS. Map is for General Reference Purposes Only",
scalebarUnit: "Feet",
legendLayers: [ll]
pt.format = 'pdf';
pt.layout = 'Letter ANSI A Portrait';
pt.preserveScale = true;
//Set Scale Here
pt.outScale = Number(scl);
console.log(pt.outScale);
//var sr = new SpatialReference(2260);
//var sr = new SpatialReference(3857); //map.spatialReference);
var params = new PrintParameters();
params.map = map;
params.outSpatialReference = map.spatialReference; //new SpatialReference(102100);
params.template = pt;
var printTask = new PrintTask(urlToThePrintServer);
printTask.on("error", function(error) { alert(error.code)});
printTask.on("complete", openprintmap);
printTask.execute(params);
Any help is greatly appreciated!
George Hilton
Town of Queensbury, NY
