I am trying to get multiple parameters (status, target_gdb,...) for each feature class within the Map. The number of feature classes is variable, so I can't set a specific number of parameters. I thought to call another python script (secondary_script) to:
- pass 3 values (a,b,c) from the original script to the secondary_script
- get the parameters for each feature class (x,y)
- return two parameters (x,y) from secondary_script to original_script.
I've never done this before and it's not working, probably for various reasons, but the most basic is that the secondary_script is not prompting for the necessary parameters (x,y). Is there a way to do this, and if so, how? I also tried assigning the GetParameterAsText to (3) and (4), but that didn't work either. I'm at a loss.
Original script:
import secondary_script
# call the secondary_script
secondary_script.module_name(a,b,c)
Secondary script:
import arcpy, os
from original_script import a,b,c
x = arcpy.GetParameterAsText(0)
y = arcpy.GetParameterAsText(1)
def copyLayerToGDB(a,b,c,x,y):
