I have a series of functions that scrape data out of a number of tables in a MySQL db. Everything to date has been working, but I need to add an enhancement. Each of the tables has a date field that indicates the date of a particular permit that has been issued. For example, to get all the building permits for the year to date I can use:
query = """SELECT idProject, idController, siteAddress,
siteApn,projectName, projectType,dateCreated,
datePermitIssued, permitNumber,applicationApprovedBy
FROM master_db.saltlakecountybuildingpermits
where datePermitIssued > '2019-12-31 23:59:59'
and siteAddress is not null;""" <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>However, line 5 needs to be passed the date the script last ran. I can capture that time stamp easily but I haven't been able to figure out how to pass its value as a variable to the query. For example:
ts = '2020-03-04 12:21:00'
where datePermitIssued > f'{ts}'
and siteAddress is not null;""" <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>ts is the last time the script ran and what I am hoping for, but no beuno (line 7 tosses an error). Once I put this into production, I only want to grab any records new since the last time the script was run, typically over night as a scheduled task.
