Hello.
I've been searching around trying to figure out why this is happening, but can't seem to find much. I tried looking into ESRI's workarounds for this error, but no luck with those.
I am writing a Python script to be used as an Arc tool. I am down to the last 3 lines of code in the script, and I keep getting this 000732 error.
File "C:\Projects\CreateSamples\CreateSamples.py", line 147, in <module>
arcpy.CalculateField_management(sampevents, "SAMPLE_ID", "[FID] + 1", "VB", "")
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\management.py", line 3360, in CalculateField
raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Table: Dataset C:\Projects\CreateSamples\SampleFeatureClasses\Sample_Events does not exist or is not supported
Failed to execute (CalculateField).
Failed to execute (CreateSamplesTest).
However, the Sample_Events shapefile in question does in fact exist. It is an output of the previous step in the script. In addition, all paths do work. They are set as workspaces by the user when running the tool. Other data within these folders seems to work fine, but for some reason this one layer is holding me up from finishing this thing.
I can add the shapefile to ArcMap and do the field calc, table export, and event layer creation manually, but ideally it should all work within the script/tool.
Copied the entire script below. Not sure if I am copying it correctly...
Thanks for any help!
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> sys<SPAN class="punctuation token">,</SPAN> string<SPAN class="punctuation token">,</SPAN> os<SPAN class="punctuation token">,</SPAN> subprocess
centerline <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
stname <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
dtsid <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN>
width <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN>
gisdata <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">)</SPAN>
sampfcdata <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Convert centerline into an LRS for creating event layer later.</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CreateRoutes_lr<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> dtsid<SPAN class="punctuation token">,</SPAN> gisdata<SPAN class="operator token">+</SPAN><SPAN class="string token">"\\"</SPAN><SPAN class="operator token">+</SPAN>centerline<SPAN class="operator token">+</SPAN><SPAN class="string token">"_LRS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"LENGTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"LOWER_LEFT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"0"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"IGNORE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"INDEX"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#TEMP DELETE FIELDS</SPAN>
addfields <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPINS"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
addfields <SPAN class="operator token">=</SPAN> max<SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> addfields<SPAN class="punctuation token">)</SPAN>
fieldtag <SPAN class="operator token">=</SPAN> str<SPAN class="punctuation token">(</SPAN>addfields<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">while</SPAN> <SPAN class="punctuation token">(</SPAN>addfields <SPAN class="operator token">></SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>DeleteField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"F_"</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
addfields <SPAN class="operator token">=</SPAN> addfields <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>DeleteField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"ADJWIDTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ESTAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"RAWSAMP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLES"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SA_W"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLF"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJUSTED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPINS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMP_1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPDIST"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLEN"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPSTRT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"LENGTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"WIDTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLE_ID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SEGMENT_ID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"BEGIN_MP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"END_MP"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Add and calculate necessary fields to create sample event measures. </SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddGeometryAttributes_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"LENGTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"FEET_US"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
length <SPAN class="operator token">=</SPAN> <SPAN class="string token">"LENGTH"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJWIDTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJWIDTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"["</SPAN><SPAN class="operator token">+</SPAN>width<SPAN class="operator token">+</SPAN><SPAN class="string token">"]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"ADJWIDTH\" > 26"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJWIDTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"26"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"CLEAR_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ESTAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"RAWSAMP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLES"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SA_W"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLF"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJUSTED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPINS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMP_1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPDIST"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLEN"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPSTRT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ESTAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"["</SPAN><SPAN class="operator token">+</SPAN>length<SPAN class="operator token">+</SPAN><SPAN class="string token">"] * [ADJWIDTH]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"RAWSAMP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[ESTAREA]/2500"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLES"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Round(([RAWSAMP] + 0.5),0)"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[ESTAREA] / [SAMPLES]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SA_W"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[SAMPAREA] / [ADJWIDTH]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"SA_W\" <= 50"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLF"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"50"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"SA_W\" > 50 AND \"SA_W\" <= 75"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLF"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"75"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"SA_W\" > 75 AND \"SA_W\" <= 125"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLF"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"100"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"SA_W\" > 125 AND \"SA_W\" <= 175"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLF"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"150"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"SA_W\" > 175"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLF"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"200"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[ADJWIDTH] * [SAMPLF]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"ADJAREA\" < 1500"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"1500"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"ADJAREA\" > 3500"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJAREA"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"3500"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ADJUSTED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Round((([ESTAREA] / [ADJAREA]) + 0.5),0)"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"ADJUSTED\" < 6"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPINS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"ADJUSTED\" >= 6 AND \"ADJUSTED\" < 11"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPINS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"ADJUSTED\" >= 11 AND \"ADJUSTED\" < 16"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPINS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"3"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"ADJUSTED\" >= 16 AND \"ADJUSTED\" < 41"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPINS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"4"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"ADJUSTED\" > 40"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPINS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Round(([ADJUSTED] * 0.17),0)"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMP_1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"(["</SPAN><SPAN class="operator token">+</SPAN>length<SPAN class="operator token">+</SPAN><SPAN class="string token">"] - ([SAMPLF]*[SAMPINS])) / ([SAMPINS] + 1)"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPDIST"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[SAMP_1]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLEN"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"["</SPAN><SPAN class="operator token">+</SPAN>length<SPAN class="operator token">+</SPAN><SPAN class="string token">"]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPSTRT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"0"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"SAMPLEN\" >= 200"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLEN"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[SAMPLF]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPSTRT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[SAMP_1]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Add fields based on the maximum number of samples, and calculate.</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"F_"</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"SAMPINS\" > "</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="operator token">+</SPAN><SPAN class="string token">" - 1"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"F_"</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[SAMPSTRT] + (([SAMPDIST] + [SAMPLF])*("</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="operator token">+</SPAN><SPAN class="string token">"-1))"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SWITCH_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"F_"</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"0"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Add fields to improve formatting.</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLE_ID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"LONG"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SEGMENT_ID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"LONG"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NAME"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"WIDTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHORT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"BEGIN_MP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"END_MP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NULLABLE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NON_REQUIRED"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SEGMENT_ID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"["</SPAN><SPAN class="operator token">+</SPAN>dtsid<SPAN class="operator token">+</SPAN><SPAN class="string token">"]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NAME"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"["</SPAN><SPAN class="operator token">+</SPAN>stname<SPAN class="operator token">+</SPAN><SPAN class="string token">"]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"WIDTH"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[ADJWIDTH]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"BEGIN_MP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[SAMPSTRT]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"END_MP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[SAMPSTRT] + [SAMPLEN]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Export first sample measures. Only export specific fields.</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>FeatureClassToFeatureClass_conversion<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> sampfcdata<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Samples_1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[SAMPLE_ID], [SEGMENT_ID], [NAME], [WIDTH], [LENGTH], [BEGIN_MP], [END_MP]"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Select based on data that exists in F_n fields, and calculate BMP and EMP fields based on selection. Then, export that selection as a new feature class.</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"\"F_"</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="operator token">+</SPAN><SPAN class="string token">"\" <> 0"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"BEGIN_MP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[F_"</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="operator token">+</SPAN><SPAN class="string token">"]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"END_MP"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[F_"</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="operator token">+</SPAN><SPAN class="string token">"]+[SAMPLEN]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>FeatureClassToFeatureClass_conversion<SPAN class="punctuation token">(</SPAN>centerline<SPAN class="punctuation token">,</SPAN> sampfcdata<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Samples_"</SPAN><SPAN class="operator token">+</SPAN>fieldtag<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[SAMPLE_ID], [SEGMENT_ID], [NAME], [WIDTH], [LENGTH], [BEGIN_MP], [END_MP]"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Merge all exported feature classes.</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> sampfcdata
fclist <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
sampevents <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:\\Projects\\CreateSamples\\SampleFeatureClasses\\Sample_Events"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Merge_management<SPAN class="punctuation token">(</SPAN>fclist<SPAN class="punctuation token">,</SPAN> sampevents<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Calculate SAMPLE_ID field.</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>sampevents<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SAMPLE_ID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[FID] + 1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"VB"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Export table.</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>TableToTable_conversion<SPAN class="punctuation token">(</SPAN>sampevents<SPAN class="punctuation token">,</SPAN> gisdata<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Sample_Events_Table"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Make route event layer\samples feature class.</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeRouteEventLayer_lr<SPAN class="punctuation token">(</SPAN>gisdata<SPAN class="operator token">+</SPAN><SPAN class="string token">"\\"</SPAN><SPAN class="operator token">+</SPAN>centerline<SPAN class="operator token">+</SPAN><SPAN class="string token">"_LRS"</SPAN><SPAN class="punctuation token">,</SPAN> dtsid<SPAN class="punctuation token">,</SPAN> gisdata<SPAN class="operator token">+</SPAN><SPAN class="string token">"Sample_Events_Table"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"LINE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[BEGIN_MP]"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"[END_MP]"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> gisdata<SPAN class="operator token">+</SPAN><SPAN class="string token">"\\"</SPAN><SPAN class="operator token">+</SPAN>centerline<SPAN class="operator token">+</SPAN><SPAN class="string token">"_Samples"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
