private void QueryTask_ExecuteRelationshipQueryCompleted(object sender, RelationshipEventArgs e) { IEnumerable<Graphic> graphics = e.Result.RelatedRecordsGroup.First().Value; RelationshipResult pr = e.Result; if (pr.RelatedRecordsGroup.Count == 0) { RelatedRowsDataGrid.ItemsSource = null; } else { foreach (var pair in pr.RelatedRecordsGroup) { RelatedRowsDataGrid.ItemsSource = pair.Value; MyFDG.ItemsSource = pair.Value; } } }
private void QueryTask_ExecuteRelationshipQueryCompleted(object sender, RelationshipEventArgs e) { //This line gets you the all features returned from the Relationship Query IEnumerable<Graphic> graphics = e.Result.RelatedRecordsGroup.First().Value; // There are two ways to filter either using Where clause or using the ObjectIDs property // before you set the Where clause to return all records 1=1 I think // Here instead lets use the ObjectIDs approach, first get rid of the old Where _featureLayer.Where = null //remember _featureLayer is l //ObjectIDs takes an int[] and with a little Linq we can get that array // I am assumning you have included OBJECTID in your outfields when you defined the query int[] objectIds = graphics.Select(g => (int)g.Attributes["OBJECTID"]).ToArray(); //now set the ObjectIDs on our FeatureLayer _featureLayer.ObjectIDs = objectIds; //Update the FeatureLayer to 'redraw' the new filtered set of Features _featureLayer.Update(); //And I hope this worked. you could rebind the layer to the grid to make sure all is good MyFDG.GraphicsLayer = _featureLayer; }
//The OID of the current related feature that the user selected private int _currentLocationId; private void SpatialQueryCompleted(object sender, QueryEventArgs e) { if ( e.FeatureSet.Features.Count() == 0 ) return; Graphic graphic = e.FeatureSet.Features[0]; //Assign the location OID to internal field so can use when a new record is created _currentLocationId = Convert.ToInt32(graphic.Attributes["OBJECTID"]); RelationshipParameter parameter = new RelationshipParameter { ObjectIds = new[] { _currentLocationId }, RelationshipId = 0, OutFields = new[] { "OBJECTID" } }; _queryTask.ExecuteRelationshipQueryCompleted += RelationshipQueryCompleted; _queryTask.ExecuteRelationshipQueryAsync(parameter); }
private void ExecuteAdd() { //Create the new Graphic object and set the default values for the attributes Graphic graphic = new Graphic(); ... graphic.Attributes.Add("LOCATION_OID", _currentLocationId); _featureLayer.Graphics.Add(graphic); //Set the bound GraphicsSource so the DataForm is loaded with the new record GraphicSource = graphic; }
private void DeleteButton_Click(object sender, System.Windows.RoutedEventArgs e) { _featureLayer.Graphics.Remove(MyFeatureDataGrid.SelectedGraphics[0]); }
<!-- RELATED LINK RESOURCE--> <common:HierarchicalDataTemplate x:Key="TreeViewItemTemplate"> <StackPanel Orientation="Horizontal" Margin="0"> <!--<Ellipse Fill="Transparent" Height="6" Width="6" StrokeThickness="2" Stroke="Black" Margin="0,0,10,0"/>--> <!--<TextBlock Text="FeatureID: " HorizontalAlignment="Left" FontSize="10" Margin="0"/>--> <TextBlock x:Name="TextBlockRelate" Text="{Binding Attributes[APN]}" HorizontalAlignment="Left" FontSize="10"/> </StackPanel> </common:HierarchicalDataTemplate> <!--END RELATED LINK RESOURCE--> <basics:TreeView x:Name="SelectedWellsTreeView" MaxHeight="180" Grid.Column="0" Margin="1" ItemsSource="{Binding}" BorderBrush="Gray" BorderThickness=".5" SelectedItemChanged="SelectedWellsTreeView_SelectedItemChanged" ItemTemplate="{StaticResource TreeViewItemTemplate}" />
private void addrowButton_Click(object sender, RoutedEventArgs e) { var g = new Graphic(); if (l != null && l.LayerInfo != null && l.LayerInfo.Fields != null) { foreach (var f in l.LayerInfo.Fields) { g.Attributes[f.Name] = null; // g.Attributes["APN"] = RelateIdTextBlock.Text; // g.Attributes["APN"] = SelectedWellsTreeView.SelectedValue.ToString()); } } else { //g.Attributes["sf_311_serviceoid"] = 21467; //g.Attributes["agree_with_incident"] = (Int16)1; //g.Attributes["DateTime"] = DateTime.UtcNow; //g.Attributes["cient_ip"] = "unknown"; //g.Attributes["notes"] = string.Format("Added - {0} - local time", DateTime.Now); // g.Attributes["APN"] = 2146700000; //g.Attributes["GEN_PLAN"] = "GPk"; } l.Graphics.Add(g); }
foreach ( var pair in pr.RelatedRecordsGroup ) { MyFDG.ItemsSource = pair.Value.Select(g => g.Attributes); }
l.Initialized += (s, e) => { l.UpdateCompleted += UpdateCompleted; l.UpdateFailed += UpdateFailed; l.Update(); };
void l_Initialized(object sender, EventArgs e) { l.Initialized += (s, f) => { l.UpdateCompleted += UpdateCompleted; l.UpdateFailed += UpdateFailed; l.Update(); }; // var l = sender as FeatureLayer; // l.Update(); }
l = new FeatureLayer() { ID = "MyLayer", Url = "http://myserver/ArcGIS/rest/services/Relate/FeatureServer/1", Mode = FeatureLayer.QueryMode.Snapshot, Where = "1=1" };
l = Map.Layers["RelatedFeatureLayer"];
<esri:FeatureLayer ID="RelatedFeatureLayer" Url="http://myserver/ArcGIS/rest/services/Relate/FeatureServer/1" />
//Modified initialzed method l.Initialized += (s, e) => { l.UpdateCompleted += UpdateCompleted; l.UpdateFailed += UpdateFailed; l.Update(); }; private void UpdateFailed(object sender, TaskFailedEventArgs e) { MessageBox.Show(e.Error.Message); } private void UpdateCompleted(object sender, EventArgs e) { MessageBox.Show("WooHoo!"); }
<!-- RELATED LINK RESOURCE--> <common:HierarchicalDataTemplate x:Key="TreeViewItemTemplate"> <StackPanel Orientation="Horizontal"> <Ellipse Fill="Transparent" Height="6" Width="6" StrokeThickness="2" Stroke="Black" Margin="0,0,10,0"/> <TextBlock Text="{Binding Attributes[APN]}" FontWeight="Bold" HorizontalAlignment="Left" FontSize="10"/> </StackPanel> </common:HierarchicalDataTemplate> <!--END RELATED LINK RESOURCE--> <Border x:Name="RelateResultsDisplay" Background="#77919191" BorderThickness="1" CornerRadius="5" HorizontalAlignment="Right" VerticalAlignment="Center" Visibility="Collapsed" Margin="5" Padding="5" BorderBrush="Black"> <Border.Effect> <DropShadowEffect/> </Border.Effect> <Grid x:Name="RelatedRowsGrid" HorizontalAlignment="Right" Background="White" VerticalAlignment="Top" MinHeight="200" Margin="10" Width="Auto"> <Grid.RowDefinitions> <RowDefinition Height="Auto"/> <RowDefinition MaxHeight="170" Height="*" /> </Grid.RowDefinitions> <Grid.ColumnDefinitions> <ColumnDefinition Width="140" /> <ColumnDefinition Width="Auto" /> </Grid.ColumnDefinitions> <TextBlock Text="Wells: " Margin="4,10,10,6" Foreground="Black" TextWrapping="Wrap" FontWeight="Bold" FontSize="10" /> <basics:TreeView x:Name="SelectedWellsTreeView" Grid.Row="1" Grid.Column="0" Margin="2" BorderBrush="Black" BorderThickness="1" ItemsSource="{Binding}" SelectedItemChanged="SelectedWellsTreeView_SelectedItemChanged" ItemTemplate="{StaticResource TreeViewItemTemplate}" /> <TextBlock Margin="4,10,60,6" TextWrapping="Wrap" Grid.Column="1" Text="Tops related to the selected well: " FontSize="10" FontWeight="Bold" /> <slData:DataGrid x:Name="RelatedRowsDataGrid" AutoGenerateColumns="False" HeadersVisibility="All" BorderThickness="1" HorizontalScrollBarVisibility="Hidden" Grid.Row="1" Grid.Column="1" IsReadOnly="False" VerticalAlignment="Stretch" HorizontalAlignment="Stretch" Margin="2"> <slData:DataGrid.Columns> <slData:DataGridTextColumn CanUserSort="False" Binding="{Binding Attributes[PARCELID]}" Header="Parcel Number"/> <slData:DataGridTextColumn CanUserSort="False" Binding="{Binding Attributes[ADDRNMBR]}" Header="Number"/> <slData:DataGridTextColumn CanUserSort="False" Binding="{Binding Attributes[ADDRNAME]}" Header="Name"/> <slData:DataGridTextColumn CanUserSort="False" Binding="{Binding Attributes[GEN_PLAN]}" Header="General Plan"/> </slData:DataGrid.Columns> </slData:DataGrid> <!--<esri:FeatureDataForm x:Name="MyFeatureDataForm" FeatureLayer="{Binding Path=Layers[AP], ElementName=Map}" IsReadOnly="False" LabelPosition="Left" />--> <!--<esriWidgets:FeatureDataGrid Grid.Row="1" x:Name="MyFDG" Height="170" Map="{Binding ElementName=Map}" GraphicsLayer="{Binding Layers[RelateFeatureLayer], ElementName=Map}" Style="{StaticResource FeatureDataGridStyle1}" />--> <!--<Border x:Name="FeatureDataFormBorder" Visibility="Collapsed" HorizontalAlignment="Left" VerticalAlignment="Center" Margin="10,10,10,0" Width="300" Height="300" > <Border.Effect> <DropShadowEffect Color="Black" Direction="-45" BlurRadius="20" Opacity=".75" /> </Border.Effect> <esri:FeatureDataForm x:Name="RelatedRowsDataGrid" FeatureLayer="{Binding Path=Layers[RelateFeatureLayer], ElementName=Map}" IsReadOnly="False" LabelPosition="Left" /> </Border>--> </Grid> </Border> <!--END GRID FOR RELATED (AP) --> <StackPanel VerticalAlignment="Bottom"> <Button Content="AddRow" Click="Button_Click"/> <esri:FeatureDataGrid x:Name="MyFDG" Height="250"/> </StackPanel>
//For FDG -- Jennifer's code l = new FeatureLayer() { ID = "MyLayer", Url = "http://myserver/ArcGIS/rest/services/Relate/FeatureServer/1", Mode = FeatureLayer.QueryMode.Snapshot, Where = "1=1" }; l.OutFields.Add("*"); l.Initialized += (s, e) => { if (l.InitializationFailure != null) MessageBox.Show(l.InitializationFailure.Message); }; l.InitializationFailed += (s, e) => { if (l.InitializationFailure != null) MessageBox.Show(l.InitializationFailure.Message); }; l.Initialized += new EventHandler<EventArgs>(l_Initialized); l.Initialize(); MyFDG.GraphicsLayer = l; //End for FDG Jennifer's code- //for Relate queryTask = new QueryTask("http://myserver/ArcGIS/rest/services/Relate/MapServer/0"); queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted; queryTask.ExecuteRelationshipQueryCompleted += QueryTask_ExecuteRelationshipQueryCompleted; queryTask.Failed += QueryTask_Failed; //End for relate //Jennifer's Code to update the feature data grid with a where 1=1 all records void l_Initialized(object sender, EventArgs e) { var l = sender as FeatureLayer; l.Update(); } FeatureLayer l; private void Button_Click(object sender, RoutedEventArgs e) { var g = new Graphic(); if (l != null && l.LayerInfo != null && l.LayerInfo.Fields != null) { foreach (var f in l.LayerInfo.Fields) { g.Attributes[f.Name] = null; } } else { //g.Attributes["sf_311_serviceoid"] = 21467; //g.Attributes["agree_with_incident"] = (Int16)1; //g.Attributes["DateTime"] = DateTime.UtcNow; //g.Attributes["cient_ip"] = "unknown"; //g.Attributes["notes"] = string.Format("Added - {0} - local time", DateTime.Now); g.Attributes["APN"] = 2146700000; g.Attributes["GEN_PLAN"] = "GPk"; } l.Graphics.Add(g); } //End Jennifer's code //Relate Code private void SelectedWellsTreeView_SelectedItemChanged(object sender, RoutedPropertyChangedEventArgs<object> e) { if (e.OldValue != null) { Graphic g = e.OldValue as Graphic; g.UnSelect(); g.SetZIndex(0); } if (e.NewValue != null) { Graphic g = e.NewValue as Graphic; g.Select(); g.SetZIndex(1); //Relationship query RelationshipParameter relationshipParameters = new RelationshipParameter() { ObjectIds = new int[] { Convert.ToInt32(g.Attributes[SelectedWellsTreeView.Tag as string]) }, OutFields = new string[] { "PARCELID, APN, ADDRNMBR, ADDRNAME, GEN_PLAN" }, RelationshipId = 0, OutSpatialReference = Map.SpatialReference }; queryTask.ExecuteRelationshipQueryAsync(relationshipParameters); } } void QueryTask_ExecuteRelationshipQueryCompleted(object sender, RelationshipEventArgs e) { RelationshipResult pr = e.Result; if (pr.RelatedRecordsGroup.Count == 0) { RelatedRowsDataGrid.ItemsSource = null; } else { foreach (var pair in pr.RelatedRecordsGroup) { RelatedRowsDataGrid.ItemsSource = pair.Value; } } } //End relate
<esri:Map x:Name="_map" Background="Transparent" WrapAround="true" IsLogoVisible="False"> <esri:ArcGISDynamicMapServiceLayer ID="Ad Soft" Url="http://sdm7/ArcGIS/rest/services/Ad_Soft/MapServer" /> <esri:ArcGISDynamicMapServiceLayer ID="BaseLayer" Url="http://sdm7/arcgis/rest/services/MapOverview/MapServer" /> <!-- FeatureLayer with Url of Related Table --> <esri:FeatureLayer ID="Feature_Layer" Url="http://sdm7/ArcGIS/rest/services/Demos/Demo_RelatedDataEntry/FeatureServer/1" /> </esri:Map>
1.With the FeatureDataGrid1.Bind a FeatureLayer (not the actual FeatureLayer in my map, though) to the grid but initially have the FeatureLayer as null 2.Do the related records query as before but when I get the results back I set the ObjectId property on my bound FeatureLayer and call Update() on the FeatureLayer 3.To add a record I need to create the Graphics object and first initialize all my Attributes to their default values for the data type 4.Then can add the record to the FeatureLayer and it will show up in the Grid 5.Then you just call Save() on the FeatureLayer 6.For updates the user is editing the graphic so just need a call to save no searching like before
FeatureLayer RelateFeatureLayer = new FeatureLayer(); RelateFeatureLayer = null;
Do the relate records query as before
Membros conectados podem postar, seguir atualizações e mais. Novo aqui? Registre uma conta gratuita.
