I'm trying to export my ArcGIS Pro map series to PNG. I'm using the MapSeries example code #2 from Esri (http://pro.arcgis.com/en/pro-app/arcpy/mapping/mapseries-class.htm ). I keep getting an Invalid page number error.
Any help is much appreciated!!
See below code and error:
Code:
import arcpy, os, sys
relpath = "Z:\\41708.02 VAGuidehouse - MAHSO Call 1\\300TIG\\315Maps\\Maps_DDF"
aprx = arcpy.mp.ArcGISProject("CURRENT")
l = aprx.listLayouts()[0]
if not l.mapSeries is None:
ms = l.mapSeries
if ms.enabled:
for pageNum in range(1, ms.pageCount + 1):
ms.currentPageNumber = pageNum
print("layoutName{0}".format(ms.pageRow.Market))
pageName = ms.pageRow.Market
l.exportToPNG(relpath + "\\PNG_Test\\S7_MKTOVW_{0}".format(ms.pageRow.Market) + ".png")
Error:
File "<string>", line 10, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\arcobjects\_base.py", line 109, in _set
return setattr(self._arc_object, attr_name, cval(val))
ValueError: Invalid page number '1'.
