I need to create a script that will copy our county's parcel data, maintained in SDE/SQL, to a file geodatabase. This script will be run as a scheduled task over the weekend. What GP tool do you recommend for this process? Consider that our schema is 'set in stone' and we have no relationship classes to maintain. I have tested both CopyFeatures_management and FeatureClassToFeatureClass_conversion. Both work. FC to FC is slightly faster, but speed is not really an issue. In theory, CopyFeatures, run with Overwrite = True, matches our workflow as we are not converting to a shapefile or coverage. FeatureClassToGeodatabase_conversion may be the best tool, as there are about 25 feature classes that need to be copied.
Also, I need to ensure that the machine running the script is able to connect to the SDE data. We are using DBO-schema with OS authentication. The script will likely be run by the same server that houses our SDE. Does anyone have experience with a similar scenario?
Thanks, Adam
