I am trying to create separate opacity sliders for two (or more) layers within the same mapservice.I tried to modify Public Information Samplehttp://tmappsevents.esri.com/website/Public-Information-Map/min/index.html but was not successful.I have 7 polygon layers [0,1,2,3,4,5,6] I want user to change the opacity on each of them. Is there any easy way to do this? It seems setOpacity() can???t be used on esri.layers.ImageParameters.Any help (or additonal examples) would be much appreciated.Using ArcGIS server 9.3.1Thanks,Chris<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Toggle Layers, Identify Only Visible Layers </title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/esri/dijit/css/Popup.css"> <link type="text/css" href="http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.2/themes/redmond/jquery.ui.all.css" rel="Stylesheet" /> <style> #slider{ width:155px; height:8px; border:1px solid #999; margin-top: 5px; margin-bottom:15px; } </style> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6"></script> <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.7/jquery.min.js"></script> <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.2/jquery-ui.min.js"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("esri.dijit.Popup"); var layer, map, visible = []; var identifyTask, identifyParams; $(document).ready(function(){ $("#slider").slider({ value:100, min:0, max:100, step:5, slide : function(evt, ui){ dynlayer.setOpacity(parseFloat(ui.value/100)); } }); }); function init() { //setup the popup window var popup = new esri.dijit.Popup({ fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])) }, dojo.create("div")); var initialExtent = new esri.geometry.Extent({"xmin":-8513951.985121,"ymin":4786968.660565,"xmax":-8248256.864588,"ymax":4996406.126118,"spatialReference":{"wkid":102100}}); // var initialExtent = new esri.geometry.Extent(-9571474.89, 4592552, -9502681, 4638414, new esri.SpatialReference({ // wkid: 102100 // })); map = new esri.Map("map", { extent: initialExtent, infoWindow: popup }); dojo.place(popup.domNode, map.root); dojo.connect(map, "onLoad", function(map) { initIdentify(map); }); // Attach an onclick listener for each check box. // Update layer visiblity when each is checked clicked. var checkBoxes = dojo.query('input[type=checkbox]'); dojo.forEach(checkBoxes, function(cb) { dojo.connect(cb, 'onclick', updateDynLayerVisibility); }); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"); map.addLayer(basemap); //Use the ImageParameters to set the visible layers in the map service during ArcGISDynamicMapServiceLayer construction. var imageParameters = new esri.layers.ImageParameters(); imageParameters.layerIds = [0,1,2,3]; imageParameters.layerOption = esri.layers.ImageParameters.LAYER_OPTION_SHOW; //can also be: LAYER_OPTION_EXCLUDE, LAYER_OPTION_HIDE, LAYER_OPTION_INCLUDE dynlayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.dvrpc.org/ArcGIS/rest/services/TCDI/MapServer", { "imageParameters": imageParameters }); map.addLayer(dynlayer); } function initIdentify(map) { dojo.connect(map, "onClick", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new esri.tasks.IdentifyTask("http://gis.dvrpc.org/ArcGIS/rest/services/TCDI/MapServer"); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 12; identifyParams.returnGeometry = true; // identifyParams.layerIds = [0,1,2,3]; identifyParams.layerIds = dynlayer.visibleLayers; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; } function updateDynLayerVisibility() { var inputs = dojo.query(".dyn_item"); visible = []; for (var i = 0, il = inputs.length; i < il; i++) { if (inputs.checked) { visible.push(inputs.id); } } // If no layers are visible set the array value to = -1 // and disconnect the identify task if (visible.length === 0) { visible = [-1]; map.infoWindow.hide(); } // Update Identifys layers identifyParams.layerIds = visible; // Update layer visiblity dynlayer.setVisibleLayers(visible); } function executeIdentifyTask(evt) { if (visible.length === 1 && visible[0] == -1){ map.infoWindow.clearFeatures(); map.infoWindow.show(evt.mapPoint); } else { identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask.execute(identifyParams); deferred.addCallback(function (response) { // response is an array of identify result objects // return an array of features. return dojo.map(response, function (result) { var feature = result.feature; feature.attributes.layerName = result.layerName; if (result.layerName === 'Year 2002'){ var template = new esri.dijit.PopupTemplate({ title: "<FONT color=#CB2F27><B>{PROJECTNAM}</B></FONT>", description: "<B>Location:</B>{MUN_NAME}, {CO_NAME} County, {STATE}<br>" +"<B>Amount: </B>{AMT_WEB}<br>" +"<B>Year Awarded: </B>{YR}<br>" +"<B>Project Number: </B>{PROJECTNUM}<br>" +"<B>Project Type: </B>{PROJECTTYP}<br>" +"<B>Project Description: </B>{PROJ_DESC}{PROJ_DESC2}{PROJ_DESC3}{PROJ_DESC4}", mediaInfos: [{ "title": "study area", "caption": "click for larger image", "type": "image", "value": { "sourceURL": "{PHOTO_TH}", "linkURL": "{PHOTO}" } }] }); feature.setInfoTemplate(template); } else if (result.layerName === 'Year 2003'){ var template = new esri.dijit.PopupTemplate({ title: "<FONT color=#F0BD56><B>{PROJECTNAM}</B></FONT>", description: "<B>Location:</B>{MUN_NAME}, {CO_NAME} County, {STATE}<br>" +"<B>Amount: </B>{AMT_WEB}<br>" +"<B>Year Awarded: </B>{YR}<br>" +"<B>Project Number: </B>{PROJECTNUM}<br>" +"<B>Project Type: </B>{PROJECTTYP}<br>" +"<B>Project Description: </B>{PROJ_DESC}{PROJ_DESC2}{PROJ_DESC3}{PROJ_DESC4}", mediaInfos: [{ "title": "study area", "caption": "click for larger image", "type": "image", "value": { "sourceURL": "{PHOTO_TH}", "linkURL": "{PHOTO}" } }] }); feature.setInfoTemplate(template); } return feature; }); }); map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); } } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div> Layers: <br /> <input type='checkbox' class='dyn_item' checked='checked' id='0' />Year 2002<br /> <input type='checkbox' class='dyn_item' checked='checked' id='1' />Year 2003<br /> Opacity:<br/> <div id="slider"> </div> </div> <div id="map" style="width:1200px; height:600px; border:1px solid #000;"></div> </body> </html>
