I am having a problem with using two geoprocessing widgets in the developer edition of the webapp builder. Both widgets operate correctly alone however when two gp widgets are placed in the same web map running one seems to break the other. Both widgets required drawing a polygon and that is where the problem occurs.
First, I run either widget successfully getting my desired result. Then, I go and attempt to run the other widget and upon drawing my polygon it disappears. I can start drawing but once I finish the polygon by double click or just by releasing, depending on the drawing tool selected, the shape I have drawn just disappears. The order which the tools are run does not matter. The problem occurs with whichever is run second.
Has anyone else experienced this and/or know of a workaround?
