I created a secure map in Portal, shared it, made a Web Mapping Application using the Story Map Journal template, and downloaded the template. I extracted the files on a different web server and made the necessary config changes for Portal. I registered the app in Portal. When I try to view the app in the browser, it prompts for my login information using the ESRI authentication form as expected.
When I submit my login info, it shows this on the page and never displays the story map:
The JavaScript console shows the following error:
TypeError: Cannot read property '0' of undefined
at http://myserver.com/myapp/app/viewer-min.js?v=1.1:1:162579
at c (http://js.arcgis.com/3.11/init.js:76:221)
at d (http://js.arcgis.com/3.11/init.js:76:10)
at b.Deferred.resolve.callback (http://js.arcgis.com/3.11/init.js:77:350)
I suspect it may have to do with the DEFAULT_SHARING_URL. I had to guess at this value because I'm not an admin, but the one used in the code at least sees the Map Journal on the server (because other examples I tried immediately errored out), and it prompts me for my login. However, when I try to hit the DEFAULT_SHARING_URL in my web browser, it gives me an error "Invalid URL Error: 400". So it partially works. Is there a permission or port that needs to be changed? Or is something else going on?
