I'm using an Address Locator I made that's based on ZIP code polygons. I'm using the Geolocator sample from the JS API Samples website. When a user enters a zip other than what's in my dataset, nothing happens. I would like to have an alert box pop-up with a msg. I though this could be done using an if...else statement, but doesn't seem to be working. I've tried else if (candidate.score != 100) but that doesn't work. The way my locator is setup, the results are either a score of 100 or nothing. The results look like this when it works:dojo.io.script.jsonp_dojoIoScript3._jsonpCallback({"candidates" : [{"address" : "48161","location" :{"x" : -9292144.7345,"y" : 5147689.1911},"score" : 100,"attributes" : {}}]});Or like this when it doesn't:dojo.io.script.jsonp_dojoIoScript4._jsonpCallback({"candidates" : []});Could I use the onError(error) event? If so, how would I do that?See below for the code in question:
//pop up alert msg
function show_zip_alert()
alert("Please eneter a valid ZIP Code");
//Locator functions
function locate() {
map.graphics.clear();
map.infoWindow.hide();
var add = dojo.byId("address").value.split(",");
var address = {
ZIP: add[0]
locator.addressToLocations(address);
function showResults(candidates) {
var candidate;
var symbol = new esri.symbol.SimpleMarkerSymbol();
symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_DIAMOND);
symbol.setColor(new dojo.Color([0,0,0,0.8]));
var points = new esri.geometry.Multipoint(map.spatialReference);
for (var i=0, il=candidates.length; i<il; i++) {
candidate = candidates;
if (candidate.score === 100) {
var attributes = { address:candidate.address, score:candidate.score, locatorName:candidate.attributes.Loc_name };
var graphic = new esri.Graphic(candidate.location, symbol, attributes);
map.graphics.add(graphic);
map.graphics.add(new esri.Graphic(candidate.location, new esri.symbol.TextSymbol(attributes.address).setOffset(0, 10)));
points.addPoint(candidate.location);
else
show_zip_alert();
map.setExtent(points.getExtent().expand(3));
}It also seems I don't really need to use an array (and then have to loop through it) since I'm only using the ZIP field of the locator, but I don't really know how to remove that. Also I'm not showing the InfoWindow. I'm not really a developer, so any help would be greatly appreciated.
