I’m editing an AGOL-hosted related table in Collector 10.3.2 and the required fields seem to work in Android but not in iOS. One is a date field (pump date), one is a short integer (pump volume). Although I set the default values of both to “” in the definition template, the pump date defaults to null and the pump volume defaults to 0 in iOS, but neither are required. Do you know how I can require them in iOS or is this a bug?
Ben
