OK I am following the oauth2sample example for Android.
I have setup the app and it has a Client ID. I also setup the app with the Redirect URI for which I put in "oauthdemo://auth". In Strings.xml I have the following....
<string name="portal_url">https://www.arcgis.com/</string>
<string name="client_id">RtVrbexXFDewENQo</string>
<string name="app_name">OAuth2Sample</string>
<string name="login_type_dlg_message">Log in with saved credentials?</string>
<string name="yes">Yes</string>
<string name="no">No</string>
<string name="enter_portal_url">Enter Portal URL</string>
<string name="OAuth2_Sample">OAuth2 Sample</string>
<string name="continue_with_saved_credentials">Continue with saved Credentials?</string>
<string name="quit_app">Quit App?</string>
In the OAuth2 java class
OAuthView oAuthView = new OAuthView(context, getResources().getString(R.string.portal_url), getResources()
.getString(R.string.client_id), new CallbackListener<UserCredentials>() {
When I run the sample I always get Error Invalid redirect_uri Error 400. Where in the oAuthView example am I supposed to input the redirect uri? I see no place for it in the code???? When I go into a web browser on the device it does take me to the correct location when I input the redirect uri and client id as follows...
https://www.arcgis.com/sharing/oauth2/authorize?response_type=code&client_id=RtVrbexXFDewENQo&redirect_uri=oauthdemo://a…
What gives?? How do I input the redirect uri into the code above to make it work?
