I want to know what is the best way via arcpy to update a feature field by referencing another features field.
I don't know if it is possible to use a updatecursor for 2 different features.
Would I just perform a temporary join and use arcpy like field calculator.
My Example of my cursor attempt.
searchcursor <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"BASE.ROADS_SG_ESC"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
updatecursor <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"escroads"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> searchcursor<SPAN class="punctuation token">:</SPAN>
RD20NAME <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">.</SPAN>getValue<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"RD20NAME"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> updatecursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">.</SPAN>getValue<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"NAME"</SPAN><SPAN class="punctuation token">)</SPAN>
NAME <SPAN class="operator token">=</SPAN> RD20NAME
updatecursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
