Experience Builder bug? Arcade expression selects 8 fields, creates new aliases, and places them in the order I want. Works perfectly in Map Viewer. However, if I click on a feature in Experience Builder, the pop-up is nearly empty except for the field name aliases.
Just for a test, I inserted the "Feature Info" widget and it displays all the information perfectly while at the same time the pop-up does not. Please see screenshot.
Thanks for any info!
Used this code originally in Map Viewer, it works fine. I also used the edited code below this and it works fine too in Map Viewer.
Pop-up Code #1
// 1. List your fields in the exact order you want them to display
var orderedFields = [
{ name: "activity", alias: "Activity" },
{ name: "init_type", alias: "Slide Type" },
{ name: "confidence", alias: "Interpretation Confidence" },
{ name: "thickness", alias: "Thickness" },
{ name: "dir_mvmt", alias: "Direction of Movement" },
{ name: "map_year", alias: "Year Mapped" },
{ name: "citable_product", alias: "Citable Product" },
{ name: "citable_product_url", alias: "Citable Product Link" }
// 2. Initialize the arrays required for the Fields Element
var fieldInfos = [];
var attributeValues = {};
// 3. Loop through the array in order
for (var i in orderedFields) {
var field = orderedFields[i];
var fName = Text(field.name);
var customLabel = field.alias;
// Grab the full value safely
var fieldValue = $feature[fName];
// Push the field configuration in the current loop order
Push(fieldInfos, {
fieldName: fName,
label: customLabel
// Pass the actual feature data to the popup
attributeValues[fName] = fieldValue;
// 4. Return the structured dictionary to the popup
return {
type: 'fields',
fieldInfos: fieldInfos,
attributes: attributeValues
Pop-up Code #2 (like the above script, this expression also works fine in Map Viewer but not in Experience Builder Pop-ups)
// 3. Loop through the array in order using for...of to access objects properly
for (var field in orderedFields) {
var fObj = orderedFields[field];
var fName = fObj.name;
var customLabel = fObj.alias;
Push(fieldInfos, { fieldName: fName, label: customLabel });
return {
type: "fields",
};-Dickie
Arcade fine in widget but not in pop-up. EB bug?
