Hi. This was working perfectly pre June 2026 update.
I have an intersect calculation here, using FeatureSetbyName $map. It also uses a field which is hidden by conditional visibility to select the project area if project areas overlap. The way it is designed if there are no project areas to choose, the field does not appear, and it instead gets the value from the single project area
Since the update, when I draw the feature it does not calculate but I move it slightly after drawing it, it does. This is currently not practical for the end user.
(see attached gif)
Kind regards, Willy
