Hi everyone,
I'm migrating from ArcGIS Pro 3.1 to 3.4 and updating my code from `arcgis.mapping.WebMap` to `arcgis.map.Map` accordingly.
**Environment:**
- ArcGIS Pro 3.4
- arcgis 2.4.0
- arcgis-mapping 4.30.0
- Python 3.11 (conda env)
- Windows 10
**The issue:**
When instantiating `Map(item=webmap_item)`, I get the following error:
TypeError: 'MockValSer' object is not an instance of 'SchemaSerializer'
File "...arcgis\map\map_widget.py", line 488, in _update_source
self._webmap_dict = self._webmap.dict()
File "...arcgis\map\_dataclasses\_webmap_spec.py", line 73, in dict
d = super().model_dump(
File "...pydantic\main.py", line 475, in model_dump
return self.__pydantic_serializer__.to_python(
This seems to be a conflict between `arcgis-mapping 4.30.0` and pydantic v2. I've tried multiple pydantic v2 versions (2.4.0, 2.5.0, 2.13.4) with their matching `pydantic-core` versions, reinstalling from both pip and conda-forge, but the error persists.
Has anyone successfully used `arcgis.map.Map` on Windows with ArcGIS Pro 3.4? If so, what exact version of pydantic are you running?
Thanks!
