tldr; Is it possible to smart launch to a feature in a layer not represented in an Indoor category?
More information. I'd like to be able to smart launch to features that are not part of a category in the Explore tab. My use case is the following. Using a proxy, a library call number is converted to its appropriate shelf row in our library. I have the rows represented as points in my indoor map. The proxy builds a URL to the indoor map referencing the shelf row id, opening the map focused on the relative location of the call number in question. The problem I am encountering is that the URL parameters for smart launching seem to require the layer in question to be part of a category listed under Explore. I'd really like to not do that, as having a bunch of points with ids meaningless to end users is less than ideal.
Any thoughts would be very appreciated. In the image below you can see my "sneaky" attempt to hide the row id category by assigning it blank icons and renaming it to _. 😂
