I created a new Field Map for doing stormwater inspections that is very similar to a Field Map I had already put together for sanitary inspections. On both field maps the inspection records are related to the parent features via GUID, the only difference is that the stormwater inspections have 5 related assets (there are many different types of storm features that get the same inspection) while the sanitary manholes only have 1 related asset (only manholes are inspected).
With the sanitary manhole inspections, our team has been opening the previous inspection record in Field Maps and making a copy of it since not a lot changes from inspection to inspection and it saves them a lot of time. This has worked well for us.
But as I'm setting up the stormwater inspection map, for some reason I am not seeing the Copy button like I do in the sanitary map. I have double checked that all their editing settings look the same, and I tried following the advice in this thread to uncheck and re-check copy settings in Field Maps Designer: Copy Features not availabe for certain feature classes in Field Maps
Has anyone else run into this issue? Could it be related to the relationship classes? Photos included to show what Copy button I am referring to:
Sanitary Inspection with Copy Button
Storm Inspection without Copy Button
Thank you!
