I've just wasted hours of my life because this tool does not return a helpful error message. I was trying to aggregate chlorophyll-a data in this living atlas multidimensional datasets. I'm aggregating over user defined time ranges and the tool bombs out returning this error message
Failed to execute. Parameters are not valid.
ERROR 000800: The value is not a member of 2002-07-04T00:00:00 | 2002-07-05T00:00:00 | 2002-07-06T00:00:00 | 2002-07-07T00:00:00 | 2002-07-08T00:00:00 | 2002-07-09T00:00:00 | 2002-07-10T00:00:00 | 2002-07-11T00:00:00 | 2002-07-12T00:00:00 | 2002-07-13T00:00:00 | 2002-07-14T00:00:00 | 2002-07-15T00:00:00 | 2002-07-16T00:00:00 | 2002-07-17T00:00:00 | 2002-07-18T00:00:00 | 2002-07-19T00:00:00 | 2002-07-20T00:00:00 | 2002-07-21T00:00:00 | 2002-07-22T00:00:00 | 2002-07-23T00:00:00 | 2002-07-24T00:00:00.......
Now you might say, well its obvious, one of your parameters is not in the date list.
Well I'm being very kind to you by not showing you the 4000 or so other lines in this error message! Every date since July 2002!
So the error message says my date is not in list of valid values, but which is it!!!!
The tools error message needs to state at the top which input value is missing from the accepted list not just say a value is missing. Multidimensional datasets are very large!
I've had to spend several hours to track down that the multidimensional data is actually missing some dates and it was just really bad luck for me that I happen to have chosen one of these missing dates.
I hope someone from esri contacts the oceans team and points this out to them, as users need to be made aware that this dataset that is an an Authoritative dataset on living atlas is actually incomplete! For the record I discovered that 2020-06-29 and what was the killer for me 2020-07-01 are missing, there may be more?
