I'm seeking clarification on setting the maximum number of instances for a service in ArcGIS Server 11.5
Prior versions of Esri Wikis, arctitecture recommendations, etc have stated the maximum should be no more than n+1, where n is the number fo CPU cores. So on an 8 core machine, the recommendation would be no more than 9 instances for a service.
Is that still the recommendation for current version of ArcGIS Server, 11.5 and up? The current documentation provides no guidance or warnings about setting this too high. For example, setting it to 14 on an 8 core server.
Anticipate and accommodate users—ArcGIS Server | Documentation for ArcGIS Enterprise
I've had conflicting recommendations from Esri support, with one analyst recommending we set the max instances of a service to equal the max number of editors we expect (14 in that case on a 8 core server), and another (different support ticket) recommending the n+1 limit for a heavily used service.
