Split is an operation in ArcGIS that breaks a line feature into two features at the split location. This operation can be performed in ArcGIS Pro or via the rest API split payload. Split respects the the line split policy, which is either update delete or , delete insert insert.
However, often you want to more control on how and what lines are split, the attributes that are distributed between the two split lines, and what kind of features causes the line to split. For that we have authored an Attribute rule that allows you to do this. This rule was authored specially for the Utility Network because it has special logic, however it will work with other line features outside the controller dataset.
The rule allows you to configure a point feature that when that feature is created on a line feature it will split the line and transfer the attributes from the point feature to the line features. This example configures a switch feature that splits the medium voltage line.
You can add this Arcade expression as a new Calculation Attribute rule to the point class you wish to split the line. The rule does a spatial query, detects the line, updates its geometry and creates a new line feature. The payload for both edits can be changed to include additional attributes and logic.
// NOTE: This is not tested on multipart lines
// NOTE: The intersect seems to be failing on large lines in GCS, we could evaluating buffering the point for a better intersect
//Expects($feature, 'SplitInt', 'SplitText');
// Exit Early Code
// If you want to exit and not split a interesting line based on a point value, fill out a dict
// with field name as the key and the values as an array to exit early
// Make sure to list these fields in the Expects
var exit_early_values = {} //'SplitInt', [200],'SplitText', ['DontSplitTheLine']);
// The field to not move to a new field, edit tracking fields need to be remove
// All fields listed here, need to be in upper case, they are forced to upper in the logic below.
var remove_fields_from_new_feature = ['SHAPE_LENGTH', 'GLOBALID', 'OBJECTID'];
// The line class to split
var line_class_name = "ElectricDistributionLine";
// This is used to get Non Editable fields, do not change the fields from *
var line_fs = FeatureSetByName($datastore, "main.ElectricDistributionLine", ['*'], true);
// Set this when using decimal degrees, it adjust the tolerances
var decimal_degrees = false;
// How man decimals to round coordinates to check if identical
// GCS should use a large value, such as 9
// PCS should use a value such as 4
var compare_coordinate_round_value = 2;
// When walking the line to split, a line is created between pairs of vertex
// this value is the distance ito determine if the created point is on that line
// GCS should use a small value, such as 0.0001
// PCS should use a larger value, such as 0.1
var point_on_line_tol = 0.1;
// For some scales, and large GCS lines, intersect does not return intersecting lines
// Setting this value uses a polygon buffer of the point for the intersect
// PCS should use a value such as 0.02
// GCS should use a value such as 0.00000002
var buffer_pnt_distance = 0;
if (decimal_degrees) {
compare_coordinate_round_value = 9;
point_on_line_tol = 0.00001;
if (buffer_pnt_distance != 0) {
buffer_pnt_distance = 0.00000002;
// option to skip logic to remove duplicate vertex at the start and end of line, this may be caused by splitting on
// a vertex
var remove_dup_vertex = true;
// When the point and line are un controlled, we cannot split a line when the point is midspan(not at a vertex)
var is_un_controlled = true;
// ************* End User Variables Section *************
function get_fields_by_type(feat, convert_string, param, value) {
var fields = Schema(feat).fields;
var return_fields = [];
var func = Decode(Lower(convert_string), "lower", Lower, "upper", Upper, Text);
for (var f in fields) {
if (fields[f][param] == value) {
var fld_name = fields[f].name;
if (!IsEmpty(convert_string)) {
fld_name = func(fld_name);
Push(return_fields, fld_name);
return return_fields;
function set_date_type(feat, dict) {
// Dates need to be set to date types for some platforms
var dt_keys = get_fields_by_type(feat, dict, 'type', 'esriFieldTypeDate');
for (var k in dict) {
if (IndexOf(dt_keys, Upper(k)) == -1) {
continue;
dict[k] = Date(dict[k]);
return dict;
function pDistance(x, y, x1, y1, x2, y2) {
// adopted from https://stackoverflow.com/a/6853926
var A = x - x1;
var B = y - y1;
var C = x2 - x1;
var D = y2 - y1;
var dot = A * C + B * D;
var len_sq = C * C + D * D;
var param = -1;
if (len_sq != 0) //in case of 0 length line
param = dot / len_sq;
var xyz, yy;
var is_vertex = false;
// Do we want to use tolerenaces
if (compare_coordinate(x, y, x1, y1)) {
is_vertex = true;
if (compare_coordinate(x, y, x2, y2)) {
is_vertex = true;
if (param < 0) {
//is_vertex = true;
xyz = x1;
yy = y1;
else if (param > 1) {
//is_vertex = true;
xyz = x2;
yy = y2;
else {
//is_vertex = false;
xyz = x1 + param * C;
yy = y1 + param * D;
var dx = x - xyz;
var dy = y - yy;
return [Sqrt(dx * dx + dy * dy), [xyz, yy], is_vertex];
function compare_coordinate(x, y, x1, y1) {
// TODO, probably move to Equals and compare the geometry
if ((Round(x1, compare_coordinate_round_value) != Round(x, compare_coordinate_round_value)) ||
(Round(y1, compare_coordinate_round_value) != Round(y, compare_coordinate_round_value)) ){
return false;
return true;
function pop_keys(dict, keys) {
var new_dict = {};
if (IndexOf(keys, Upper(k)) != -1) {
continue;
new_dict[k] = dict[k];
return new_dict;
function remove_vertex(path_array) {
if (!remove_dup_vertex){
return path_array;
var new_path = [];
var current_path = path_array[0];
var vertex_count = Count(current_path);
if (vertex_count > 2) {
if (compare_coordinate(current_path[0][0],current_path[0][1],current_path[1][0],current_path[1][1])) {
for (var i in current_path) {
if (i != 1) {
Push(new_path, current_path[i]);
current_path = new_path;
new_path = [];
path_array[0] = current_path;
current_path = path_array[-1];
if (Count(current_path) > 2) {
if (compare_coordinate(current_path[-1][0],current_path[-1][1],current_path[-2][0],current_path[-2][1])) {
if (i != vertex_count - 2) {
path_array[-1] = current_path;
return path_array;
function cut_line_at_point(line_geometry, point_geometry, exit_when_not_at_vertex) {
var point_coord = null;
var interpolate_z = false;
// Check if the line has already been converted to a dict
var line_shape = null;
if (TypeOf(line_geometry) == 'Dictionary') {
line_shape = line_geometry;
} else {
line_shape = Dictionary(Text(line_geometry));
// Get the Z info and determine if Zs should be return/interpolated in lines
// TODO: Handle M's
if (Count(line_shape['paths'][0][0]) >= 3 && IsEmpty(point_geometry.Z)) {
point_coord = [point_geometry.X, point_geometry.Y];
interpolate_z = true;
} else if (Count(line_shape['paths'][0][0]) >= 3 && IsEmpty(point_geometry.Z) == false) {
point_coord = [point_geometry.X, point_geometry.Y, point_geometry.Z];
} else {
// If the point is at the start or end, skip splitting line
if (compare_coordinate(point_coord[0],point_coord[1], line_shape['paths'][0][0][0], line_shape['paths'][0][0][1]) ||
compare_coordinate(point_coord[0],point_coord[1], line_shape['paths'][-1][-1][0],line_shape['paths'][-1][1])) {
return [];
var min_distance = point_on_line_tol * 2;
var segment_id = [];
var line_path = line_shape['paths'];
for (var i in line_path) {
var current_path = line_path[i];
// Loop over vertex, exit when at last vertex
for (var j = 0 ; j < Count(current_path) - 1 ; j++) {
var from_coord = current_path[j];
var to_coord = current_path[j + 1];
var shortest = pDistance(point_coord[0], point_coord[1], from_coord[0], from_coord[1], to_coord[0],to_coord[1]);
var distance = shortest[0];
var coordinates = shortest[1];
var isVertex = shortest[2];
//push(segment_id, [i, j, coordinates, isVertex,distance*100000])
if (distance <= min_distance) {
segment_id = [i, j, coordinates, isVertex];
min_distance = distance;
if (IsEmptyButBetter(segment_id))
return [];
// Since we not on a vertex, pro for UN classes, needs to insert one, so we cannot split the line
if (exit_when_not_at_vertex && segment_id[-1] == false){
return [];
var new_path_1 = Slice(line_path,0,segment_id[0]+1);
var new_path_2 = Slice(line_path,segment_id[0]);
var new_seg_1= slice(new_path_1[-1],0, segment_id[1]+1);
Push(new_seg_1, segment_id[2]);
new_path_1[-1] = new_seg_1;
var new_seg_2= slice(new_path_2[0],segment_id[1] + 1);
Insert(new_seg_2,0, point_coord);
new_path_2[0] = new_seg_2;
return [new_path_1, new_path_2];
// Used to check different empty null states, override of core IsEmpty
function IsEmptyButBetter(data) {
if (IsEmpty(data)) return true;
for (var x in data) return false;
return true;
function check_exit_early(feat) {
if (IsEmptyButBetter(exit_early_values)) {
return false;
for (var k in exit_early_values) {
if (Includes(exit_early_values[k], feat[k])) {
return true;
return false;
if (check_exit_early($feature)) {
return;
var intersecting_lines;
if (buffer_pnt_distance == null || buffer_pnt_distance <= 0) {
intersecting_lines = Intersects($feature, line_fs);
} else {
intersecting_lines = Intersects(Buffer($feature, buffer_pnt_distance), line_fs);
var in_point_geometry = Geometry($feature);
var update_features = [];
var new_features = [];
var new_geoms = [];
// Loop through lines to split
for (var line_feature in intersecting_lines) {
var polyline_1 = null;
var polyline_2 = null;
new_geoms = cut_line_at_point(Geometry(line_feature), in_point_geometry, is_un_controlled);
// If a split was not found, do not modify the feature
//return text(new_geoms);
if (Count(new_geoms) != 2) {
continue;
var new_geom_1 = new_geoms[0];
var new_geom_2 = new_geoms[1];
if (Count(new_geom_2) == 0 || Count(new_geom_1) == 0) {
continue;
var line_spat_ref = Geometry(line_feature).spatialReference.wkid;
var new_geom_1 = remove_vertex(new_geom_1);
var new_geom_2 = remove_vertex(new_geom_2);
polyline_1 = Polyline({
"paths": new_geom_1,
"spatialReference": {
"wkid": line_spat_ref
polyline_2 = Polyline({
"paths": new_geom_2,
var polyline_1_length = Length(polyline_1);
var polyline_2_length = Length(polyline_2);
// Convert feature to dictionary to get all its attributes
var line_att = Dictionary(Text(line_feature))['attributes'];
var atts_to_remove = get_fields_by_type(line_feature, 'Upper', 'editable', false);
for (var i in remove_fields_from_new_feature) {
var fld = Upper(remove_fields_from_new_feature[i]);
if (IndexOf(atts_to_remove, fld) != 1) {
continue;
Push(atts_to_remove, fld);
line_att = set_date_type(line_feature, pop_keys(line_att, atts_to_remove));
// Check length of new shapes, adjust the current feature to the longest segment
if (polyline_1_length > polyline_2_length) {
Push(update_features, {
'globalID': line_feature.globalID,
'geometry': polyline_1
Push(new_features, {
//'globalID': GUID(),
'geometry': polyline_2,
'attributes': line_att
} else {
'geometry': polyline_1,
// Only include edit info when a split was required
if (Count(update_features) > 0 && Count(new_features) > 0) {
var results = {};
results['edit'] = [{
'className': line_class_name,
'updates': update_features,
'adds': new_features
return results;
return;
Credit to Mike Miller, original author of this rule, more details here .
Download a mobilegdb data with the split rule.
