We are seeing unusual behaviour on Android:
- Pan map
- Click on location with points, lines and polygons.
- Only the polygons appear in pop-up.
- Pan map again or interact with the map. Polygons appear and update in pop-up list. Points and lines do no
- Close the pop-up pane
- Repeat step 3 without panning, interacting at same location - points, lines and polygons appear
- Repeat from step 1 - panning the map - only the polygons appear
Issue is unique to Field Maps on Android. Tested Pixel 6 Pro, Samsung galaxy. 5 devices impacted. Tested several maps.
iOS seems to not want to show the point on first click either but subsequent interactions are OK without closing the pop-up.
@ChrisDunn1 is this something you're aware of?
Cheers,
Chris
