I think it would be beneficial to include an Arcade function that finds the nearest feature (or potentially features) from a featureSet to a specific feature/geometry.
This is a routine task that has been asked about several times before across the various forums:
https://community.esri.com/t5/arcgis-online-questions/using-arcade-to-find-the-nearest-address-point/m-p/108741#M5171
https://community.esri.com/t5/arcgis-online-questions/arcade-get-4-nearest-addresses-from-point-feature/m-p/463470#M23381
https://community.esri.com/t5/arcgis-field-maps-questions/nearest-address-calculation-expression-in-field/m-p/1176989#M3585
I have written my own code to get my desired result here:
var portalItem = FeatureSetByPortalItem(Portal('https://redacted.com/portal'), 'redactedportalitemid', 1, ["featureDescription"], true)
var inputFeature = $feature
var nearestFeature
var relevantFeaturesBuffer = Buffer($feature, 500, "meters")
var relevantFeatures = Intersects(portalItem, relevantFeaturesBuffer)
function compareShortestDistance(a,b){
return Distance(Geometry(a), Geometry(inputFeature)) - Distance(Geometry(b), Geometry($feature))
for (var feature in relevantFeatures){
if (nearestFeature == null) {
nearestFeature = feature
} else if (compareShortestDistance(nearestFeature, feature) > 0){
return nearestFeature.featureDescription
This does work and meet my needs, however I feel that it is still inefficient. You may notice that there is a buffer and intersection used to filter "relevant" features that are nearby (hardcoded 500m). This is necessary because if the portalItem contains a large number of features then the distance comparison becomes prohibitively slow. If instead there is a nearest function created by ESRI it should be possible to better optimize the function by taking advantage of backend tools like spatial indexes.
What I'm proposing is a function like such:
Nearest(featureSet, feature/geometry, numberOfReturnedFeatures?) => feature/featureSet
