I have a standalone python script that uses multiprocessing and it is hitting an intermitent error when I use MakeFeatureLayer on a SQL Server table (which should support concurrent read access) across multiple processes. Similar problems have been reported here and here, but there are some differences and no clear solutions offered. The script runs fine with one worker process but fails intermitently when I go beyond that. Any ideas on why MakeFeatureLayer would fail like this? Am I wrong in assuming that is should work? Thanks
Here is the python code the recreates the problem:
import arcpy
import os
import multiprocessing
BEE_FC = r'C:\Users\dmorri28\Documents\ArcGIS\Projects\MyProject\CC-SQL2k16-ERC-SDE.sde\ROW_Habitat.SDE.USA_Bee_Occurrence'
MP_PROCESSORS = 2
NUM_TASKS = 20
NUM_ITERATIONS = 20
PID = os.getpid()
def run_mp (task_idx):
try:
lyr = arcpy.management.MakeFeatureLayer(BEE_FC, f"intersect_lyr_{PID}")[0]
arcpy.Delete_management(lyr.name)
except Exception as e:
print (f"PID: {PID} TASK: {task_idx} Exception: {str(e)}")
e.add_note(f"TASK: {task_idx}")
#raise
return
def run ():
for i in range(0,NUM_ITERATIONS):
print (f"Iteration: {i}")
p = multiprocessing.Pool(MP_PROCESSORS)
p.map(run_mp, list(range(0,NUM_TASKS)), 1)
p.close()
if __name__ == '__main__':
run ()
Here is the output - you can see it fails on iteration 1 and 17 plus there is also a mysterious licensing error that pops up every once in a while...
Iteration: 0
Iteration: 1
PID: 45800 TASK: 1 Exception: Failed to execute. Parameters are not valid.
ERROR 000732: Input Features: Dataset C:\Users\dmorri28\Documents\ArcGIS\Projects\MyProject\CC-SQL2k16-ERC-SDE.sde\ROW_Habitat.SDE.USA_Bee_Occurrence does not exist or is not supported
Failed to execute (MakeFeatureLayer).
Iteration: 2
Iteration: 3
Iteration: 4
Iteration: 5
Iteration: 6
File "<string>", line 1, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\multiprocessing\spawn.py", line 122, in spawn_main
exitcode = _main(fd, parent_sentinel)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\multiprocessing\spawn.py", line 131, in _main
prepare(preparation_data)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\multiprocessing\spawn.py", line 244, in prepare
_fixup_main_from_name(data['init_main_from_name'])
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\multiprocessing\spawn.py", line 268, in _fixup_main_from_name
main_content = runpy.run_module(mod_name,
File "<frozen runpy>", line 226, in run_module
File "<frozen runpy>", line 98, in _run_module_code
File "<frozen runpy>", line 88, in _run_code
File "c:\ROW\DEV\GitRepos\ROW_as_habitat\test\test_mp.py", line 1, in <module>
import arcpy
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 77, in <module>
from arcpy.geoprocessing import gp
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\__init__.py", line 14, in <module>
from ._base import *
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 14, in <module>
import arcgisscripting
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgisscripting\__init__.py", line 131, in <module>
from ._arcgisscripting import *
RuntimeError: The Product License has not been initialized.
Iteration: 7
Iteration: 8
Iteration: 9
Iteration: 10
Iteration: 11
Iteration: 12
Iteration: 13
Iteration: 14
Iteration: 15
Iteration: 16
Iteration: 17
PID: 35152 TASK: 0 Exception: Failed to execute. Parameters are not valid.
Iteration: 18
Iteration: 19This is a windows system running ArcGIS Pro 3.4.0 under a Named User License that is authorized to work offline.
