I'm lookingfor a smart way to writeback an attribute value that is calculated in ArcGIS Pro to a hosted feature layer in ArcGIS Enterprise.
The Scenario is:
There is a point layer in ArcGIS Enterprise. I do calculations offline (Routing) using parts of the hosted feature layer as an input. (I use a few k out ofa few 100k)
I want to write back a field from the output to the hosted feature layer (Sequence).
Is thre a smart way to do that?
Overwriting the layer is not an option.
I tried building a model that loops through my result layer, picking the feature with the matching ID and Field calculated the Value back. Unfortunately that process is extremely slow (aprox. 1 Value per Second).
