Hello all, I am currently on Enterprise 11.5 and using a local dataset for my routing so the number of stops are not a problem.
I am attempting to create a Route using our data that will traverse every road segment within out City and am having troubles with the route navigation.
The workflow I have established is to create a Stops layer that was developed from using the Feature to Point on the Road dataset used in the Network dataset, however when using the Preserve 1st and Last stop (so they start at City Hall and return back to it) the route that is created is very erratic. Within the ND I have also included Turn penalties, and set to calculate U-Turns at dead-ends & Intersections (originally made for 1st responders). I might need to create a new Travel Mode? Is there something else I need to consider when creating this?
The video below shows the erratic behavior of the path it wants to take. (This is a test using 'Find Best') option. The small red dot is the travel path.
