Is there any way to configure a utility network so that it behaves like the geometric network when adjusting line vertices as explained below?
In the GN, if you were to delete all the vertices between start/end nodes, when you finish editing the water main it would carry all the service lines over as still snapped to the main. It would create vertices along the main at those fitting/service line connections.
In the UN, it doesn't behave the same way. I tried setting edge connectivity to "Any vertex" for Water Main / Distribution Main asset type, but that doesn't fix the problem because it's precisely when the vertices are removed as the water main feature gets realigned.
After deleting this vertex (under the X) and finishing the sketch, it doesn't pull the service line and junction over with it. Our GIS Technicians have to use 2 steps to re-draw the service line graphic: move junction point and then use "Replace Geometry" tool. Using "Replace Geometry" tool alone won't allow you to snap an end vertex anywhere along the water main feature. It may seem like a minor issue, but when you're doing this all day endlessly, with two clicks instead of one, it adds up to much time wasted.
