This is a recent problem I just encountered and not sure if it's related to the newest ArcGIS Pro Update 3.5.2 or if it's related to the Nearmap on AGOL issue that has been ongoing for the past few weeks (https://www.nearmap.com/status) or both?
The issue is that using the Attribute Transfer lags severely when I have Nearmap via AGOL (the lastest working version that has come back online finally), is turned on.
The tool works fine if I disable Nearmap from AGOL. It also works fine with other imagery (WTMS Service) and another WMS service we have access to. So I know it has something to do with the latest imagry that Nearmap and ESRI have temporarily got working. Nearmap has said there are issues still, but wanted to double check this wasn't also a possiblity that the 3.5.2 update is aslo maybe adding to the problem as well?
Not sure if this should be a bug report or not, because I'm not sure if it's only Nearmap via AGOL that is the issue, or if it's also partly due to the 3.5.2 update as well?
