I am trying to print a map that contains clustered points rendered using a pie chart.
Using the SDK's print widget the generated PDF does not render the points using clusters and piecharts but as points (cluster centers ?) with unique value rendering.
See CodePen https://codepen.io/christophesuter/pen/wBBXQmw
Same thing using esri/rest/print:
Same thing when using rest/print https://codepen.io/christophesuter/pen/xbbzmBo
Anyone knows if this a known limitation of the printService ?
