In web map viewer, I'm able to set up field properties such as decimal points. However, in Experience Builder, when a table uses layer settings (i.e., field properties set in web map viewer), I cannot change the order of table fields. All the fields are showing based on alphabetic order and there's no way to change it. If I let the table use custom settings instead of layer settings, I can change field order by dragging the fields, but all the field properties set up in web map viewer are not available. I wonder if there's a way for users to change the order of table fields when the table uses layer settings. Thank you!
