I am working on a chrome extension which integrates with a site that uses esri. My extension adds custom layers. (This worked perfectly on 3.x...now they recently upgraded to 4.x, and I'm scrambling to get it working again.)
Here's my layer:
import { FetchTileRequest, postWindowMessage } from "@/types/messages";
import { BaseZoom, SystemZoom, TileInfo } from "@/types/layers";
import { loadModules } from 'esri-loader';
import BaseTileLayerProperties = __esri.BaseTileLayerProperties;
let BaseTileLayerClass: any = null;
export async function createCustomTileLayer(properties: BaseTileLayerProperties): Promise<__esri.Layer> {
// this is needed because direct import of BaseTileLayer doesn't work
// ("The item being added is not a Layer or a Promise that resolves to a Layer.")
if (!BaseTileLayerClass) {
[BaseTileLayerClass] = await loadModules(['esri/layers/BaseTileLayer']);
const CustomTileLayer = BaseTileLayerClass.createSubclass({
properties,
getTileUrl: function(level: number, row: number, col: number): string {
console.log("Getting tile URL", level, row, col);
return `https://proxy.com/z=${level}&x=${col}&y=${row}`;
fetchTile: function(level: number, row: number, col: number): Promise<HTMLImageElement | HTMLCanvasElement> {
console.log("Fetching tile", level, row, col);
return new CustomTileLayer(properties);
I call this with:
async getLayer(type: LayerType, zoom: BaseZoom): Promise<__esri.Layer> {
const config = this.layerConfig.getLayer(type, zoom);
return createCustomTileLayer({
title: translate(config.label),
opacity: config.opacity,
minScale: this.zoomToScale(config.minZoom),
maxScale: this.zoomToScale(config.maxZoom),
tileInfo: {
dpi: 96,
format: "png",
size: [config.tileSystem.tileSize, config.tileSystem.tileSize],
spatialReference: { wkid: 3857 },
origin: {
x: -20037508.342787,
y: 20037508.342787,
lods: this.generateLODs(config.minZoom, config.maxZoom)
And then finally:
this.window.map.add(esriLayer);
await esriLayer.load();
esriLayer.visible = true;
I can see by dumping the layers on the map that the layer is added successfully. However, fetchTile is never called, so something in these settings is causing esri not to bother querying my layer.
Here's what I'm logging:
console.log("Map view:", {
scale: this.window.view.scale,
center: this.window.view.center.toJSON(),
zoom: this.window.view.zoom,
spatialReference: this.window.view.spatialReference.toJSON()
this.window.map.layers.forEach((layer) => {
console.log(`Layer: `, layer.title, layer.loaded, layer.visible, '||',
layer.fullExtent?.xmin, layer.fullExtent?.xmax,
layer.fullExtent?.ymin, layer.fullExtent?.ymax, '||',
'minScale' in layer ? layer.minScale : "",
'maxScale' in layer ? layer.maxScale : "",
layer.type, layer.opacity,
JSON.stringify('tileInfo' in layer && layer.tileInfo ? {
'dpi': (layer.tileInfo as TileInfo).dpi,
'format': (layer.tileInfo as TileInfo).format,
'size': (layer.tileInfo as TileInfo).size,
'lods': (layer.tileInfo as TileInfo).lods.map(lod => lod.level),
'origin': (layer.tileInfo as TileInfo).origin.toJSON(),
'spatialReference': (layer.tileInfo as TileInfo).spatialReference.toJSON(),
Here's what my layer looks like:
Layer: My Custom Layer true true || -20037508.342787 20037508.34278 -20037508.34278 20037508.342787 || 73957190.94894437 70.53107352156103 base-tile 1 {"dpi":96,"format":"png","size":[256,256],"lods":[3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23],"origin":{"spatialReference":{"wkid":3857},"x":-20037508.342787,"y":20037508.342787},"spatialReference":{"wkid":3857}}
Here are some of the host site's layers, which work (if enabled):
Layer: Layer X true true || -1259927.5109 1261063.5594 -1201416.1471 2267331.5414 || 32000 0 map-image 0.8 {}
Layer: Layer Y true false || 286802.9026 658879.5627 889175.757200001 1241118.0719 || 16000 0 feature 0.8 {}
Layer: Layer Z true false || 121352.40221620945 824303.4391836704 871515.0272515337 1258709.6024793475 || 0 0 tile 1 {"dpi":96,"format":"mixed","size":[256,256],"lods":[0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15],"origin":{"spatialReference":{"latestWkid":8908,"wkid":8908},"x":-5122600,"y":10001100},"spatialReference":{"latestWkid":8908,"wkid":8908}}
Obviously the spatial reference is different, but that's expected (I'm adding a mercator layer on top of CRTM05 layers, and expecting/hoping esri will do the job of handling this). If this is the issue, what's the better approach?
If that's not the problem, what else looks suspicious?
