I have a table that has a Number field that lists the order that points should go in 1-18, and then I have a field called 'Completion' that determines whether or not work is completed at that point with the value 'complete' or 'incomplete'. I need to make a label class that selects the lowest number that is marked as incomplete by using an SQL selection. I have been trying at this for little while and have too little experience with SQL to figure it out.
Thank you.
