I would like to create a field that is auto-populated with the username of the person that last edited a different field in the survey. I am creating a form in field maps, so my thought was that it could be a hidden field in the form (is it even possible to create hidden fields in field maps form designer? I am used to using Survey123). But really it would be nice if the field had an arcade expression that always updated it with the editors username anytime the field was edited (when using the field maps form, or editing in map viewer, or editing in Arc Pro).
Example:
I have a Trap Check field layer that has the following fields:
Date of First Trap Check, Date of Second Trap Check, Date of third Trap Check
When a user checks a trap, they select one of those fields and record the date. I would like to have three other fields that are automatically updated:
Editor of First Trap Check, Editor of Second Trap Check, Editor of Third Trap Check
Those fields would automatically record the username of whoever last updated the associated Date of Trap Check field.
Does anyone know how I can accomplish this?
-Andy
