Hello, I have configured a Feature Dataset that contains a network dataset. The network functions normally in pro and processes find best route successfully. I added the Feature Dataset along with the network dataset and associated data to my enterprise geodatabase and tested the find best route and it works great. I am trying to configure portal (11.2) to use this network dataset so that I can create a solve widget to use in experience builder but when trying to configure I keep getting this error and I can not find any documentation on it anywhere -
"type": "esriJobMessageTypeInformative",
"code": 0,
"description": "AttributeError: DescribeData: Method workspaceFactoryProgID does not exist\n"
"type": "esriJobMessageTypeError",
"code": 30206,
"description": "A geoprocessing error occurred during tool execution.",
"parameters": {
"code": 0,
"description": "",
"parameters": {
"code": 0,
"description": "Error details.",
"parameters": {
"code": 0,
"description": "Traceback (most recent call last):\n"
"code": 0,
"description": " File \"D:\\Program Files\\ArcGIS\\Server\\framework\\runtime\\ArcGIS\\Resources\\ArcToolBox\\Services\\routingservices\\prs_gptool.py\", line 440, in execute\n self.prs_tool.execute()\n"
"code": 0,
"description": " File \"D:\\Program Files\\ArcGIS\\Server\\framework\\runtime\\ArcGIS\\Resources\\ArcToolBox\\Services\\routingservices\\prs.py\", line 1925, in execute\n self._validate_nd()\n"
"code": 0,
"description": " File \"D:\\Program Files\\ArcGIS\\Server\\framework\\runtime\\ArcGIS\\Resources\\ArcToolBox\\Services\\routingservices\\prs.py\", line 462, in _validate_nd\n raise arcpy.ExecuteError from None\n"
"code": 0,
"description": "arcgisscripting.ExecuteError\n"
} Does anyone have any idea on this error or can point me in the direction to get it solved?
Thanks in advance to anyone that can help.
