EDIT: original question is below. However I found another post that says the scheme actually works, it's just that the folders are named in hexadecimal instead of ZXY... and that things can be renamed using code.
I am trying to generate map tiles to use as a basemap in our scada system.
Our particular scada system requires that the tiles use the same scheme as OpenStreetMaps.
Does ArcGIS Pro have the OSM scheme built in somewhere? or do I need to recreate it using the Generate Tile Cache Tiling Scheme tool?
If I have to recreate it, how do I determine the number of scales, cell size, and origin?
Thanks!
