Pro 3.3
Related: https://community.esri.com/t5/arcgis-pro-questions/presentations-is-there-a-way-to-add-a-legend-to/m-p/1579692
From the other post:
I'm running into the problem of "I can place a map, but I can't communicate to the viewer what is on that map unless I am there to explain it to them".
Is there any way to add a legend (or actually, a straight-up layout would be best) to a presentation?
My current workaround would be to make a layout, export it, and then bring it in as an image, but I think it'd be a lot cleaner to just pull in the layout object directly?
I'd like to be able to add a full layout object to a Presentation. Among other things, being able to add a legend (and a scale bar) to your map is important when presenting it to other people.
The current workaround is to export to Image (or copy the legend as graphics, which is gross). Adding in a layout object would be cleaner.
