Hello, I am working with a field that includes numeric values as a string that appear like this: 0820;0830;0840;0850;0860;0870A;0880;0890;1050;1060;1070;1080;1100;1110;1120;1140;1150;1160.
What I would like to do is separate each value on a new line and remove leading zero/one trailing zero in my popup. I am working with the arcade script below. So far the script is working as I get a list like the following:
But the problem I am having is that I don't know how to deal with values that also include a letter. In those rare cases, it can be any letter (always at the end), and I don't know how to remove the zero that is to the left of the letter. So right now in the resulting list it looks like 870A when I would like it to look like 87A.
I cannot claim to have written the script below as I am very new to arcade. I was using Esri's AI assistant to help form the script. But I was not having any luck with the more complicated value mentioned above. Any advice that could be provided would be much appreciated. Thanks!
var inputString = $feature.OrdConcat;
var values = Split(inputString, ";");
var result = [];
for (var i in values) {
var cleanedValue = values[i];
// Remove the first leading zero
if (Left(cleanedValue, 1) == "0") {
cleanedValue = Mid(cleanedValue, 1, Count(cleanedValue) - 1);
// Check if the last character is a letter
if (IsNan(Right(cleanedValue, 1))) {
// Check if the character before the letter is a zero
if (Mid(cleanedValue, Count(cleanedValue) - 2, 1) == "0") {
cleanedValue = Left(cleanedValue, Count(cleanedValue) - 2) + Right(cleanedValue, 1);
} else if (Right(cleanedValue, 1) == "0") {
// Remove exactly one trailing zero if no letter is present at the end
cleanedValue = Left(cleanedValue, Count(cleanedValue) - 1);
Push(result, cleanedValue);
return Concatenate(result, TextFormatting.NewLine);
