I have a frustrating error that I can't figure out. Any help would be awesome.I have a web application in API 2.4, SL 4 that renders different feature layers based on data in a certain field. From there the user makes a selection and enters their name and email and an email is sent. All this seems to be working fine but after the confirmation for the email I get a null exception error with the following info:Microsoft JScript runtime error: Unhandled Error in Silverlight Application Code: 4004 Category: ManagedRuntimeError Message: System.NullReferenceException: Object reference not set to an instance of an object. at ESRI.ArcGIS.Client.Toolkit.FeatureDataForm.FieldControl_LostFocus(Object sender, RoutedEventArgs e) at MS.Internal.CoreInvokeHandler.InvokeEventHandler(UInt32 typeIndex, Delegate handlerDelegate, Object sender, Object args) at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags)I used http://www.silverlightnext.com/2010/06/send-email-from-silverlight-application.html to set up the email service. My Feature DataForm set up is as follows:xaml: <Popup x:Name="MyPopup" VerticalOffset="25" HorizontalOffset="400" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Visibility="Visible"> <Border BorderBrush="#FF51626F" BorderThickness="5"> <StackPanel x:Name="PopUpPanel" Background="LightGray" Height="Auto" Width="Auto" > <TextBlock x:Name="PopUpText" Height="40" Width="Auto" Margin="15" Text="THANK YOU VOLUNTEER!!" FontFamily="Arial" FontSize="30" HorizontalAlignment="Center" VerticalAlignment="Center" Foreground="#FF51626F"/> <TextBlock x:Name="PopUpSubText" Margin="10" Height="80" Width="Auto" Text="You will be registered for the following location and time. Please complete the required contact information below and click SAVE. Please note, your NAME and an email address is required to complete your registration. You will receive an email confirming your volunteer location." FontFamily="Arial" FontSize="14" HorizontalAlignment="Center" VerticalAlignment="Center" Foreground="#FF51626F" MaxWidth="400" TextWrapping="Wrap" /> <Border x:Name="FeatureDataFormBorder" Visibility="Visible" HorizontalAlignment="Center" VerticalAlignment="Top" Margin="10,10,10,0" Width="400" Height="300" > <Border.Effect> <DropShadowEffect Color="#FF51626F" Direction="-45" BlurRadius="20" Opacity=".75" /> </Border.Effect> <esri:FeatureDataForm x:Name="MyFeatureDataForm" FeatureLayer="{Binding Path=Layers[AllAvailableFeatureLayer], ElementName=Map}" IsEnabled="True" IsReadOnly="False" LabelPosition="Left" CommitButtonContent="Save" EditEnded="MyFeatureDataForm_EditEnded"/> </Border> <StackPanel Margin="10" Orientation="Horizontal" HorizontalAlignment="Center"> <Button x:Name="ClosePopupButton" Height="34" Width="73" Content="Close" Background="#FF51626F" FontFamily="Verdana" FontSize="14" Click="ClosePopupButton_Click" /> </StackPanel> </StackPanel> </Border> </Popup>
cs: private void FeatureLayer_MouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs args) { foreach (Layer lyr in Map.Layers) { if (lyr is FeatureLayer) { FeatureLayer featureLayer1 = lyr as FeatureLayer; for (int i = 0; i < featureLayer1.SelectionCount; i++) featureLayer1.SelectedGraphics.ToList().UnSelect(); } } FeatureLayer featureLayer = sender as FeatureLayer; SelectedFeatureLayer = featureLayer; args.Graphic.Select(); MyFeatureDataForm.FeatureLayer = featureLayer; MyFeatureDataForm.GraphicSource = args.Graphic; FeatureDataFormBorder.Visibility = Visibility.Visible; MyPopup.IsOpen = true; } private void FeatureLayer_BeginSaveEdits(object sender, ESRI.ArcGIS.Client.Tasks.BeginEditEventArgs e) { } private void FeatureLayer_EndSaveEdits(object sender, ESRI.ArcGIS.Client.Tasks.EndEditEventArgs e) { foreach (Layer lyr in Map.Layers) { if (lyr is FeatureLayer) { FeatureLayer featureLayer = lyr as FeatureLayer; featureLayer.Update(); } } SendEmail(); }
