Hello everyone,
We've been trying to export into enterprise geodatabase using local server and it seems to be throwing the following error in the local server log:
2024-12-19 17:59:46,514 INFO rid=4 'worker-4776' Core - layers/0/applyEdits (code=17002): GraphicFeatureServer::HandleRESTRequest ## requestProperties = {"computeETag":true}
2024-12-19 17:59:46,514 INFO rid=4 'worker-4776' Core - layers/0/applyEdits (code=100001): REST request received. Request size is 16354 characters.
2024-12-19 17:59:46,517 INFO rid=4 'worker-4776' Core - SetupGeoTransformation::Init (code=17002): Input Spatial Reference:: Name: 'British_National_Grid' Factory Code: 27700; Output Spatial Reference:: Name: 'Unknown' Factory Code: 0.
2024-12-19 17:59:46,517 INFO rid=4 'worker-4776' Core - SetupGeoTransformation::Init (code=17002): There is no GeoTransformation in the Server instance for the Spatial References.
2024-12-19 17:59:46,517 INFO rid=4 'worker-4776' Core - SetupGeoTransformation::Init (code=17002): There is no Default GeoTransformation in the Spatial Reference Environment.
2024-12-19 17:59:46,519 ERROR rid=4 'worker-4776' Core - GraphicFeatureLayer::Add2 (code=17000): An error occurred.
2024-12-19 17:59:46,519 ERROR rid=4 'worker-4776' Core - GraphicFeatureServer::HandleREST_ApplyEditsOperation (code=17000): An error occurred.
2024-12-19 17:59:46,520 INFO rid=4 'worker-4776' Core - layers/0/applyEdits (code=5555) (elapsed=0.005074): outBytes=195; taskName=Edit
2024-12-19 17:59:46,520 INFO rid=4 'worker-4776' Core - layers/0/applyEdits (code=100004) (elapsed=0.005074): REST request successfully processed. Response size is 195 characters.
2024-12-19 17:59:46,544 INFO rid=4 'server' MapServer-test_simple - Request handled.
One peculiar thing about this is the destination table has around 160 columns and during add (5 entries), only 2 really short strings are added but it still throws the error message above and within the code, an AggregateException is thrown with an inner exception of Exception with message "Unable to complete operation" error code 0x80004005.
We tried reducing the column count to less than 10 and it seems to be exporting successfully.
My question is, is there a limit to how many columns can we export into an enterprise geodatabase table? And if it does, how do we go about exporting into those with too much columns?
