Hi.
I'm having a problem with ArcGIS Enterprise 11.2. We have a multi-machine deployment running through an App Gateway in Azure. One of our servers refuses to connected when switching from Http and Https.
Server has problem with 6443 port machine status gets error "Error"
Failed to get the status of the server machine 'server.domain'. Could not connect to the ArcGIS component at URL 'https://server:6443/arcgis/admin/local/isAppServerStarted'. The ArcGIS component on that machine may not be running or the machine may not be reachable at this time.Error: Connection refused: connect
Code
500
I've reached out to ESRI support but wanted to know if anyone has a workflow to fix this issue. Thank you in advance!
@JakeSkinner @BhaskaraGummadi
