I built an application using ArcGIS Experience Builder and incorporated the Survey widget to collect feedback on a web map named 'StarMap_Street,' which contains roads. I successfully connected the Survey widget to the 'StarMap_Street' web map, customized Survey123 to collect comments for each selection, and auto-populate the street name from the web map into the survey.
However, when I open the Survey123 results hosted feature layer in Map Viewer, the table data appears correct, but the map only shows a single point in the middle of nowhere. I already have a geopoint field in Survey123, but I’m unsure how to correctly populate or configure it so the results align properly with the map. Any guidance?"
Thank you
