Hello, I just created an ArcGIS Pro project with about 12 map files that I need to export and edit in Adobe Illustrator. Since the AI export is no longer available, I used the SVG export option. However, when I open the SVG files in Illustrator, I've run into a few issues:
-Features within layers are missing. For example, in a region layer, some regions are showing up while others are not.
-Certain layers are not displaying the same as they do in Pro. For example, I used the buffer layer in Pro to create vignettes for certain features. When I open these buffer layers in Illustrator, they each show up as one large dissolved feature that has been merged into a compound path.
Any help is much appreciated!!!
