I've got a bunch of layers that I want to bring in as hosted feature layers from my ArcGIS Server Rest service implementation. I've got the process working but have doubts about how "create" is used vs "replace".
I see that at first, I have to use "create" to get the hosted feature layers generated, but then, as we update our enterprise data being exposed by our ArcGIS Server site, I want to replace the data in the hosted feature layers via the scheduler.
Right now, in Data Pipelines, I bring in each ArcGIS Server based feature layer and then associate that to a hosted feature layer output with the "create" option. But then, once that's done, I've been changing the "create" option to "replace".
This is a fairly laborious process. Is there a trick to this? Should I have one data pipeline for "create" on all my layers, and then have another one that uses "replace"? That way if I ever need to recreate a layer, I can use that "create" pipeline but for the standard, scheduled update process, I'd just be using the "replace" pipeline.
What's the most sensible workflow here? Ideally, I'd like to see the "create" and "replace" as a single option. So, if the layer doesn't exist, create it and if it does, just replace the data, or perhaps a toggle to allow for data replacement vs recreation of the entire hosted feature layer.
