init.js:1 Error during service worker registration: SecurityError: Failed to register a ServiceWorker for scope ('https://localhost:3001/') with script ('https://localhost:3001/service-worker.js'): An SSL certificate error occurred when fetching the script.
I am creating a get-map-coordinates widget and when i run this widget i am getting above issue in the console.
Please help me on this
in the widget.tsx
import {React, type AllWidgetProps} from 'jimu-core';
import { JimuMapViewComponent, type JimuMapView } from 'jimu-arcgis';
const { useState } = React;
const Widget = (props: AllWidgetProps<any>) => {
const [latitude, setLatitude] = useState<string>('');
const [longitude, setLongitude] = useState<string>('');
const activeViewChangeHandler = (jmv: JimuMapView) => {
if(jmv) {
jmv.view.on('pointer-move',(evt)=>{
const point: Point = jmv.view.toMap({
x: evt.x,
y: evt.y
setLatitude(point.latitude.toFixed(3));
setLongitude(point.longitude.toFixed(3))
return <div className='widget-starter jimu-widget'>
{props.useMapWidgetIds && props.useMapWidgetIds.length === 1 && (
<JimuMapViewComponent useMapWidgetId={props.useMapWidgetIds?.[0]} onActiveViewChange={activeViewChangeHandler} />
<p>
Lat/Lon: {latitude} {longitude}
</p>
</div>
export default Widget;
And in the Setting.tsx
import { React } from 'jimu-core';
import { type AllWidgetSettingProps } from 'jimu-for-builder';
import { MapWidgetSelector } from 'jimu-ui/advanced/setting-components';
const Setting = (props: AllWidgetSettingProps<any>) => {
const onMapWidgetSelected = (useMapWidgetIds: string[]) => {
props.onSettingChange({
useMapWidgetIds: useMapWidgetIds
return (
<div className='widget-setting-demo'>
<MapWidgetSelector useMapWidgetIds={props.useMapWidgetIds} onSelect={onMapWidgetSelected}/>
This is your starter widget setting area!</div>
export default Setting;
